Fireplace Suggestions? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 05:03 PM   #1
jpc
jc
Rewards Points: 162
Send a message via Yahoo to jpc
Fireplace suggestions?
My fireplace is located cadi-corner faceing out towards our living room, Kitchen, and dinning room. All open with no seperating wall. We hardly ever use it, unless your right in front of it, you wouldn't know it"s light up. My high utility bill's year round, especially in winter and summer have me looking for alternative's. What can be done with my fireplace to make it more of a heat source for that main room? Advice on making it more efficient? What i
nfo do I need to post to help with my questions? Thanks in advance.
1) main rooms combined square footage roughly 425
2) vaulted type ceiling's
jpc is offline   Reply With Quote
Old 03-31-2013, 08:39 PM   #2
Rewards Points: 222
fireplace make/model. and pics of the room.
Fix'n it is offline   Reply With Quote
Old 03-31-2013, 10:16 PM   #3
jpc
jc
Rewards Points: 162
I'm uploading pics now, in the mean time, where would I try to look on the fireplace for the make and model?
, house was built in 1982, its original to the house. Both pics are from the view point of the fireplace, let me know if differnt or more pics are needed
Sent from JC using DIY Chatroom
Old 03-31-2013, 10:27 PM   #4
Rewards Points: 222
on the back of it. and/or take a pic of it.
can you rotate the pics ?
Old 04-01-2013, 11:51 AM   #5
custom user
Rewards Points: 150
The view from the fireplace doesn't help much. I don't know what you have but you may need to upgrade. If so it would be hard to beat a good gas unit (if available) with ceramic glass. The ceramic glass has high heat transfer capability, like a flat top stove, so they are much more efficient than the cheaper alternatives.
I installed a Vermont Castings with remote control and thermostat. I was a life saver when I lost power for 5 days in sub freezing weather and used in conjunction with the furnace has noticeably reduced my power bill.
JasperST is offline   Reply With Quote
Old 04-01-2013, 12:19 PM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
First of all, is it gas, electric, or wood?
And yes, a pic OF the fireplace.
Old 04-01-2013, 12:27 PM   #7
jpc
jc
Rewards Points: 162
FIXIN-IT : this evening I'm going to clear away all that crap in front of it to take a good picture of it, to help Identify it since getting behind to look for manufacture info isnt easily accesable.
JasperST : Although upgrading isnt out of the question, I'd like to check and see if there is something that can be done to the existing FP to get more out of, eliminate the possibilities of error's from the install,make sure that everything that is suppose to be sealed up is, if in fact this is the best I'd get from it , I'd have to start budgeting and looking into alternative's, what price range was the one you installed. Thanks for your input, very much appreciated
Old 04-01-2013, 12:29 PM   #8
custom user
Rewards Points: 150
Originally Posted by jpc View Post
... what price range was the one you installed. Thanks for your input, very much appreciated
I spent about $2,200. $300 was for the piping though.
Old 04-01-2013, 01:34 PM   #9
Yes, the picture is not clear, at least is not showing the fire place and its current location. May be rotating the pic. will help.
leenamark1 is offline   Reply With Quote
Old 04-02-2013, 04:34 AM   #10
I want to say the same, rotating the above pic will help to suggest.
henrylarry6 is offline   Reply With Quote
Old 04-02-2013, 07:36 AM   #11
PoleCat's Avatar
Rewards Points: 1,646
You guys are way smarter than me. I was sitting here rotating my head and may have injured my neck.
PoleCat is offline   Reply With Quote
Old 04-02-2013, 09:38 AM   #12
Workmen's comp may apply, I will have to check into it.
oldhouseguy is offline   Reply With Quote
Old 04-02-2013, 11:11 AM   #13
Special User
Rewards Points: 1,230
We need to know what fuel your fireplaces uses (wood, gas, electric, etc) and what fuel source your central heating system uses (oil, gas, heatpump, electric, etc). For example, if your central system is natural gas and your fireplace is electric, you'll probably save the most money by not using the fireplace.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 04-02-2013, 02:26 PM   #14
jpc
jc
Rewards Points: 162
was not able move stuff in front of fireplace to take another pic, hopefully tonight.My centrol ac/heat is ran off electric, and fireplace is wood burning. Ideally would like the fireburning fireplace to allow me to back the thermostat down a few degree's. All the other rooms in the house are fine with the thermostat set at a moderate setting, So If I could get ANYTHING out of the fireplace I would hardly ever have to touch the temp settings. Ill make sure to get those pics up tonight, thanks again everyone
Old 04-02-2013, 02:34 PM   #15
custom user
Rewards Points: 150
Open wood burning fireplaces aren't very efficient, but if you have the wood you can crank 'em up. An enclosed cast iron unit is much more efficient, just don't burn too low for too long or you can get a creosote buildup. Which can set on fire. The pellet types are supposed to be pretty good too so maybe an insert would be what you need.
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
Removing a Fireplace - suggestions? BigFloyd Building & Construction 1 08-03-2006 06:01 PM
