-   General Discussion (http://www.diychatroom.com/f2/)
-   -   Fireplace Smell ...help wanted ! (http://www.diychatroom.com/f2/fireplace-smell-help-wanted-78188/)
jasonb72 08-07-2010 11:13 PM
Hi,
We are living in a home that is only 4 years old and we aren't the original owners. During this summer we have noticed that on days when the sun is beating down on the side of the house where our gas fireplace is that it seems to smell from the fireplace. At first we didn't know if was coming from the fireplace and thought it had something to do with our dishwasher or something but then we determined where the smell was coming from.
It only smells on days when the sun is out and usually from mid afternoon to early evening ( i.e. when the sun is on the side of the house with the fireplace ). The fireplace is a gas fireplace with a vent to the side of the house which I have checked and it didn't seem to have any animals in it. The smell is kinda a musty smell. I've read on some sites that it could be the insulation in the fireplace unit but I'm not sure. Also , the smell is occurring when the fireplace is off ( we don't use it very often ) .
Any ideas would be great because it's driving us nuts !
Thanks In Advance
Jason
Giles 08-07-2010 11:34 PM
From the information you provided, I would guess you have a moisture problem. Water can enter through the top of chimney if there is no chimney cap. The sunlight may be heating the outside surface and causing evaporation, thus the musky smell.
jasonb72 08-07-2010 11:46 PM
The fireplace doesn't have a chimney ( I don't think it does ). I think there is only the vent out to the side of the house.
Wildie 08-08-2010 11:56 AM
It may be a water problem that is unrelated to the chimney, other than the odor escapes via the fireplace opening.
When the sun shines, the dampness may evaporate and carry mold spores into the house.
I think that you should remove the fireplace and make a close examination for signs of moisture and mold.
Also, the outside vent should be removed and recaulked, along with any area's over-head on the roof, the soffit and siding that may allow water to get inside.
jasonb72 08-08-2010 09:51 PM
We took off the front glass of the fireplace and didn't find anything. Once the glass was off the smell seemed to go away due to the air from the room mixing with the fireplace air. I also checked the insulation in the fireplace unit and there is nothing wrong with that. We put some baking soda in there to take away any other smells and then closed it up.
I also checked in the basement where the gas line leads up to the fireplace to make sure there wasn't any moisture or mold and there was nothing.
Thus at this point I'm stumped. I will maybe check outside again to see if the vent on the side of the house has anything in it but I don't think it does.
Any other ideas ?
Giles 08-08-2010 10:34 PM
Charcoal will also absorbe odor:thumbsup:
jasonb72 08-26-2010 07:02 PM
So we thought we maybe had this one figured out but it still seems to pop up now and then when it's humid outside. I'm wondering is there even anyone we could call to have them come out and see what it is ? We can't seem to pinpoint what or where it's coming from.
Thanks Again
Jason
