Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-01-2009, 06:59 PM   #1
Lake Forest, CA
Question
Fireplace door insulation?
Howdy folks.. I recently purchased a fireplace door/screen assembly for my fireplace. Installation should be very straight forward however my fireplace has a stone facade that makes for an irregular surface.. This in turn leaves gaps between the door frame and the face of the fireplace. Would it be ok to put some R-30 insulation between the frame and the facade to fill in the gaps or would that be a fire hazard?
The installation booklet said to use Owens Corning RA-28 insulation if you wanted to use more than they supplied however I can not find it locally. Apparently RA-28 is an appliance insulation used in ovens and refrigerators and such.
Any other recommendations would be much appreciated (short of ripping it all out and doing it the correct way).
Happy new year!
Jerid
SKINNY is offline   Reply With Quote
Old 01-02-2009, 11:13 AM   #2
Lake Forest, CA
Anybody?
Old 01-02-2009, 11:22 AM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Rip it all out and do it the correct way
Old 01-02-2009, 05:11 PM   #4
Check out Roxul????
Chemist1961 is offline   Reply With Quote
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 09:10 PM
Possible to build direct-vent fireplace? DIYerself General Discussion 3 12-22-2007 11:07 PM
