Fireplace Damper - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-06-2008, 11:21 PM   #1
Fireplace damper
I grew up in a house whose fireplace damper could be opened/closed using a knob on the front of the fireplace. The house I live in now has a fireplace whose damper can only be reached by sticking one's arm up into the firebox.
Is it practical to replace the existing damper with a damper that can be adjusted without having to be a contortionist?
The chimney smokes with a cap so I don't think that a cap damper will work. I'll need to stick with a throat damper.
potomac101
Potomac101 is offline   Reply With Quote
Old 01-07-2008, 11:26 AM   #2
Rewards Points: 1,232
I do not know of any way to modify a poker control damper into a rotary control one, but here is a diagram of each.
Tscarborough is offline   Reply With Quote
Old 01-08-2008, 06:57 AM   #3
I found a piece of steel rod in the basement and fashioned it into a crude "damper hook." It works pretty well and mitigates the problem of starting a fire with the damper closed.
Thanks for the pictures.
potomac101
Old 01-08-2008, 02:49 PM   #4
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
Good, because there is no easy way to replace the in the flue models
Kingfisher is offline   Reply With Quote
Old 01-26-2008, 05:21 AM   #5
chimney flue liner
I live in a bungalow. the old open fire used to suffer from problems with blowback where teh smoke filled the room
The previous occupant had a cerramic flue liner fitted. the problem was this acted like a vortex and sucked all the heat up the chimney
we have installed a multi stove which has about 1 metor of 6" enamel pipe inserted into the flue liner and also a 6" butterfly damper plate.
still a lot of heat is wasted and wonder any modifcations can be made to the liner or chimney to make it more efficient with out causing carbon monoxide poisening
I did have a swinging weighted flange plate but sadly it kept geting stuck and causing blowback.
any ideas
cheers
greatdaneman is offline   Reply With Quote
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 09:10 PM
noise from fireplace FRUSTRATEDnKY General DIY Discussions 4 12-24-2007 04:23 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
