-   -   Fireplace damper (http://www.diychatroom.com/f2/fireplace-damper-15276/)
Potomac101 01-06-2008 11:21 PM
Fireplace damper
I grew up in a house whose fireplace damper could be opened/closed using a knob on the front of the fireplace. The house I live in now has a fireplace whose damper can only be reached by sticking one's arm up into the firebox.
Is it practical to replace the existing damper with a damper that can be adjusted without having to be a contortionist?
The chimney smokes with a cap so I don't think that a cap damper will work. I'll need to stick with a throat damper.
potomac101
Tscarborough 01-07-2008 11:26 AM
1 Attachment(s)
I do not know of any way to modify a poker control damper into a rotary control one, but here is a diagram of each.
Potomac101 01-08-2008 06:57 AM
I found a piece of steel rod in the basement and fashioned it into a crude "damper hook." It works pretty well and mitigates the problem of starting a fire with the damper closed.
Thanks for the pictures.
potomac101
Kingfisher 01-08-2008 02:49 PM
Good;), because there is no easy way to replace the in the flue models
greatdaneman 01-26-2008 05:21 AM
chimney flue liner
I live in a bungalow. the old open fire used to suffer from problems with blowback where teh smoke filled the room
The previous occupant had a cerramic flue liner fitted. the problem was this acted like a vortex and sucked all the heat up the chimney
we have installed a multi stove which has about 1 metor of 6" enamel pipe inserted into the flue liner and also a 6" butterfly damper plate.
still a lot of heat is wasted and wonder any modifcations can be made to the liner or chimney to make it more efficient with out causing carbon monoxide poisening
I did have a swinging weighted flange plate but sadly it kept geting stuck and causing blowback.
any ideas
cheers
