Fireplace - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-23-2012, 06:23 PM   #1
fireplace
Outdoor fireplace
Ok, I started to build an outdoor fireplace. The base and fire box is built and the smoke chamber is about 10 inches from lentil. The flue is 12 X 12 and 3 feet. I burned a small fire and was getting smoke out of the front. There was a bit of a breeze however when the breeze stopped smoke and small ambers came out the top of the flue. My question is if I take a second flue and move the other one and have them side by side would the fix the problem. The fire box is 30X30 and 18 deep. I am not looking for much heat displacement.
Thanks.
Outdoor fireplace
Thanks.
thanks.
ssheehan is offline   Reply With Quote
Old 04-25-2012, 11:30 AM   #2
Send a message via ICQ to Specialisa
surprized thanks
I think that's right!
Specialisa is offline   Reply With Quote
Old 04-25-2012, 12:48 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,628
Ayuh,.... You've asked this same question in 3 different threads, 'n 3 times in this thread....
Are you just gonna keep askin' the question, til somebody gives ya the answer you Want,..??
Old 04-25-2012, 02:55 PM   #4
Ya, I know. If you read all three posts you would have seen that I said I was new to the forum and I was sorry for posting to different forums.
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 11:37 AM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 09:26 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
