Fire Brick - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-10-2006, 07:15 PM   #1
Rewards Points: 150
fire brick
might have posted in wrong topic, does anyone know how to cut fire bricks? I need to line a wood stove and have to trim off 2 inches to line the bottom of a wood stove. thanks
econdave is offline   Reply With Quote
Old 11-10-2006, 07:22 PM   #2
General Contractor
joasis's Avatar
Borrow a tile saw, and just take it slow and easy, or, you can use a cheaper masonry blade in a skil saw, same thing, slow and easy.
joasis is offline   Reply With Quote
Old 11-10-2006, 07:37 PM   #3
Dry diamond blade in a skilsaw works pretty good. Firebrick should be pretty soft. Googles, mask, slow. No blood.
K2eoj is offline   Reply With Quote
Old 11-11-2006, 10:45 AM   #4
Tile or brick saw will work or use a segmented diamond blade on a skilsaw.Make a series of shallow cuts periodically giving the blade a chance to cool.A brickset with a little practice will also work.
tkle is offline   Reply With Quote
Old 11-11-2006, 12:32 PM   #5
Rewards Points: 150
thanks guys, used a skill saw with a masonary blade, worked great. This forum is awesome.
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 01:11 AM
Brick: to paint or not to paint, that is the ? Turnip Painting 3 04-15-2007 11:06 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
Laminate Flooring around a brick fire place pamedic13 Flooring 6 11-21-2006 09:42 PM
