Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-01-2011, 04:57 PM   #1
Finishing Basement Wall - Stairs Along Concrete
Hey all,
I have 1/2 of a Semi-Detached and I am going to try to finish the basement of. Currently the basement is poured concrete walls. To get some grants I need to hit R-24 on all 3 exterior walls.
I have an issue with figuring out how to finish around the stairs... The stairs to the basement start about 4' off the wall and you enter from ground level into the basement facing the wall... you go down 4 steps then there is a small landing (4'x4' square) and the stairs turn right and finish going down into the basement along the concrete wall. A stretch of about 15' of basement wall. The steps of the stairs are attached to 2-2x6's on their side (e.g. 1 1/2" each for 3" width) which is snug to the concrete. Hence I have about 3" of give in the steps give or take.
How would you insulate this section of the wall? I am not sure if I am supposed to use rigid insulation, batting (but thin in this section, say R-12), or some other form of insulation?
Any tips is appreciated. Because I am going for grants and rebates for finishing the basement I am doing R24 insulation (2 x R12) and the stairs could prevent me from getting $2500 in grants .
Thoughts?
Thanks,
Rob
Rob1976 is offline   Reply With Quote
Old 02-01-2011, 05:08 PM   #2
old guy contractor
tcleve4911's Avatar
Pics would help
tcleve4911 is offline   Reply With Quote
Old 02-02-2011, 08:59 AM   #3
Here you go.. just needed to get some taken/uploaded.
This one shows the steps close the concrete... the steps are 3 feet wide, the edge along the concrete is 1 2x8 on it's side plus another board that is marginally wider 3x8 perhaps? Total width of the boards would be roughly 3.5"
This second photo shows a close up of the boards... grainy but hopefully you can make it out....
Old 02-02-2011, 09:23 AM   #4
You need to reduce the picture size a bit.
I'd use furring strips and rigid foam insulation.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Rob1976 (02-02-2011)
Old 02-02-2011, 09:26 AM   #5
Thanks Ron... would you need vapor barrier at all if you do it that way? And what about where the wood is up against concrete... that creates a vapor gap right? Would I just seal along that seam above/below the stairs?
Old 02-02-2011, 09:39 AM   #6
Experienced
Jackofall1's Avatar
Rob, I have attached a real good guide for the correct way to insulate a basement wall, good luck on your project and keep the pics coming.
http://www.buildingscience.com/docum...hterm=concrete wall insulation
The Following User Says Thank You to Jackofall1 For This Useful Post:
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 02:38 PM
Finishing old basement force4ormore Building & Construction 1 12-29-2008 03:48 PM
Concrete Basement Stairs thomasd333 Building & Construction 2 12-26-2008 05:49 PM
Concrete stairs jmat1980 Building & Construction 2 04-19-2008 12:45 AM
