Finishing 1X6 Knotty Pine T&G? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-30-2008, 06:20 AM   #1
Rewards Points: 324
I am toying with the idea of finishing my basement in knotty pine #3 1X6 T&G. I have heard before that the pine will continue to darken with age over time(to a dark brown) no matter what finish is used on it, is this true? I want just a light clear stain and I would like to keep the wood at its original VERY light color forever, is that possible?
Thank you.
tigerbalm2424 is offline   Reply With Quote
Old 01-30-2008, 08:38 AM   #2
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
Pine does not darken to a dark brown. with a clear coat it will darken to a golden brown, still light, while the heart wood darken to a med. red brown.
Kingfisher is offline   Reply With Quote
Old 01-30-2008, 08:48 AM   #3
Rewards Points: 324
Does it get darker than this if I use a clear coat?
http://www.knottypinepaneling.com/_b...mall_small.JPG
Old 01-30-2008, 02:35 PM   #4
Kingfisher's Avatar
Rewards Points: 150
The sap wood may get a little darker than that, not much, but the sap will not get anywhere as dark as the heart wood in the photo
Old 01-30-2008, 03:58 PM   #5
Rewards Points: 324
Thanks! Added Question:
Currently all my plastic outlet and switch boxes are mounted for 1/2" sheetrock. If I install the 1X6 pine over the current state boxes, do they make any special recessed type outlet/switch boxes to fit?
Or whats the best way to handle the thicker walls when it comes to outlets, switches?
Thanks!
Old 01-30-2008, 05:11 PM   #6
Custom Cabinet Maker
Just leave the tabs on all devices, snug em up and out the plates on
skymaster is offline   Reply With Quote
Old 01-30-2008, 05:30 PM   #7
Rewards Points: 324
Im not following this.......
Old 01-30-2008, 05:53 PM   #8
On all switches and outlets ie "devices" you will see 4 parts that look like ears, round critters top and bottom with holes, they will bear against the walls and allow you to tighten em up without having them pull into the hole you have cut for the boxes, just make sure you DO NOT remove them and you should be fine.
Old 01-31-2008, 09:01 AM   #9
Rewards Points: 324
This is the type of boxes I have used. The holes you speak of are on the inside so I wont be removing them.
http://www.ecmweb.com/product_depot/10-15-07.jpg
So, you are saying, leave the box as is (only protruding about 1/2 inch out from the stud)? If I put a regular cover on these boxes after the 1 inch thick pine is installed there will be a 1/2 inch gap between the receptacle cover and the receptacle itself!
Old 01-31-2008, 10:03 AM   #10
NO when you attach the outlets or switches the "ears" I mentioned will keep them flush with the pine, they will NOT allow them to be pulled into the hole when you tighten them. You will need longer 6-32 screws to reach to the box. the space will be between the "outlet and the box NOT behing the plate. Most important is to make sure you have long enuf pigtails to bring that neutral out to the device.If you really want to feel better they make extension rings that you can screw onto the box and bring the face of them out to the pine face. The other option is to just screw the devices into the pine.
Old 01-31-2008, 10:36 AM   #11
Rewards Points: 324
Got it! THanks.
Old 01-31-2008, 04:19 PM   #12
Dats Ho K ur welcome
Old 02-01-2008, 07:41 AM   #13
47_47's Avatar
Rewards Points: 90
I would also recommend that you allow the T&G to acclimate to the room for about 1 week and also put the same clear coat on all surfaces and the cut ends.
47_47 is offline   Reply With Quote
Old 02-01-2008, 07:52 AM   #14
Rewards Points: 324
Yep, found that in my research already!
Old 02-01-2008, 04:23 PM   #15
Rewards Points: 5,336
You need metal box extenders for this application. The wood is combustible and could ignite if it isn't shielded. These extenders are just metal sleeves that slide into the existing box with tabs that will rest on the wood. They are sold at the Borgs and supply houses.
Ron
Can't find studs behind knotty pine paneling David S General DIY Discussions 15 09-05-2010 05:56 PM
knotty pine paneling Unregistered Remodeling 2 03-22-2010 11:41 AM
knotty pine paneling harleyd1369 Carpentry 3 11-19-2006 11:01 AM
Cleaning knotty pine t/g boards barks Painting 3 03-21-2005 11:13 PM
Cleaning knotty pine boards barks Remodeling 4 03-17-2005 08:55 PM
