Filling Hole In Concrete Floor? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-02-2009, 11:51 PM   #1
Filling hole in concrete floor?
At the bottom of my basement stairs is a hole approximately 1 1/2- 2" wide and 6" or so deep. I believe it was where the railing for the stairs was anchored into the concrete but I'm not sure. I am having new carpet installed on 01/06 and I need to know the best product for filling in the hole. I don't know if ground water has ever come up through it, but I want to fill it and seal it to make sure none does come up. I have some left over Quickcrete bags from when I had an All-Dry waterproffing system put in. Would that be sufficient or should I use something else?
Frank_N_Stein is offline   Reply With Quote
Old 01-03-2009, 12:50 AM   #2
line the hole with black builders plastic and fill it with concrete
if u want to seal it you can but i wouldn't waste my time if i were you the plastic is sufficient enough
Dr Dave is offline   Reply With Quote
Old 01-03-2009, 06:11 AM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
2 words.......
Hydraulic
Cement
JDC is offline   Reply With Quote
Old 01-03-2009, 01:10 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,... That'll Work,... Just Fine...
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Pedestal sink - alternative to anchoring to concrete floor? aktheda Plumbing 2 03-19-2008 02:12 PM
cold concrete floor RuthP Flooring 4 02-03-2008 11:13 PM
