-   -   Filling hole in concrete floor? (http://www.diychatroom.com/f2/filling-hole-concrete-floor-34961/)
Frank_N_Stein 01-02-2009 11:51 PM
At the bottom of my basement stairs is a hole approximately 1 1/2- 2" wide and 6" or so deep. I believe it was where the railing for the stairs was anchored into the concrete but I'm not sure. I am having new carpet installed on 01/06 and I need to know the best product for filling in the hole. I don't know if ground water has ever come up through it, but I want to fill it and seal it to make sure none does come up. I have some left over Quickcrete bags from when I had an All-Dry waterproffing system put in. Would that be sufficient or should I use something else?
Dr Dave 01-03-2009 12:50 AM
line the hole with black builders plastic and fill it with concrete
if u want to seal it you can but i wouldn't waste my time if i were you the plastic is sufficient enough
JDC 01-03-2009 06:11 AM
2 words.......
Hydraulic
Cement
Bondo 01-03-2009 01:10 PM
Ayuh,... That'll Work,... Just Fine...
