Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-26-2005, 12:10 PM   #1
Post
fiberglass column repair
I need some advice on what supplies that I need to repair holes in my round fiberglass porch columns. The holes were made when the wind tore my flag and flag mount off the column.
christoni is offline   Reply With Quote
Old 06-26-2005, 01:08 PM   #2
Contractor
Bondo and paint for small holes.
Teetorbilt is offline   Reply With Quote
Old 06-26-2005, 10:27 PM   #3
In the northeast, you usually will get 2-4 years out of Bondo.
plumguy is offline   Reply With Quote
Old 06-27-2005, 12:15 AM   #4
Contractor
Bondo will work for small holes in fiberglass. It is polyester based, the same as fiberglass but is high in talc. All polyester products shrink forever and Bondo will eventually crack as plumguy pionted out.
To correctly fill these holes: Grind them open to a ratio of 6:1 or more based on depth of original substrate. If the skin is 1/4" thick, you will grind open the holes to 1-1/2" or more. Use vinylester resin to embed patches of 6 oz. fabric into the cavities, roll out all bubbles and let cure. Grind all below surface level, wear all safety equipment. Buy a few PreVal sprayers, gelcoat, acetone and PVA. Spray the gelcoat and cover with the PVA, let cure. Remove the PVA with alcohol and sand nearly smooth. Repeat the gelcoat/PVA until it stands proud and sand it all down. You can now buff or paint.
All of the above are epoxies and require the catylist MEKP (Meththyl Ethel Keytone Peroxide). Don't forget to add it to any polyester products and mix well.
To spray the gelcoat, mix with about 30% acetone and double up on the hardener.
lally column loosed from basement floor sonofthetonsured Building & Construction 8 06-28-2007 02:24 PM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing 3 06-23-2007 02:02 AM
Using fiberglass filler on a balcony darsunt Painting 2 12-31-2006 09:13 PM
How do I repair my window frame sherlock Carpentry 18 12-20-2006 09:54 AM
Concrete patch for lally column footing? AllGoNoShow Building & Construction 6 10-21-2006 09:16 PM
