Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-27-2009, 01:54 PM   #1
Question
Fiber Cement Siding
My home has fiber cement siding and I want to screw an address plaque on it. The sign comes with 2 smallish screws but I don't want to split the siding. Any suggestions?
pampie is offline   Reply With Quote
Old 02-27-2009, 02:13 PM   #2
the Musigician
DangerMouse's Avatar
Fiber Cement Siding
sure! predrill holes and use plastic anchors such as used for cement block, should hold it fine and not split.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 02-27-2009, 04:54 PM   #3
Moderator
Termite's Avatar
Fiber Cement Siding
Perfect advice from DM.
Old 02-27-2009, 05:35 PM   #4
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Fiber Cement Siding
DM advice is good. not much weight. You may actually be fine with just a pilot hole and wood screw. If you have the anchors the do that. If you don't just use the screws and then give a tug, if it doesn't seem secure then get the anchors.
Brik is offline   Reply With Quote
Old 02-27-2009, 10:26 PM   #5
Tom Struble's Avatar
Fiber Cement Siding
or just use a longer screw
Tom Struble is offline   Reply With Quote
Old 02-27-2009, 10:54 PM   #6
gravity always wins
Fiber Cement Siding
Don't breath the dust when you drill it. It's likely to be loaded with asbestos.
Old 02-27-2009, 11:21 PM   #7
Moderator
Termite's Avatar
Fiber Cement Siding
What? Fiber cement siding does not contain asbestos.
Old 02-27-2009, 11:37 PM   #8
Fiber Cement Siding
silica's not good for you either kc
Old 03-02-2009, 01:25 PM   #9
gravity always wins
Fiber Cement Siding
Depending on the age, it certainly does.
Old 03-02-2009, 01:44 PM   #10
I have gas!
Clutchcargo's Avatar
Fiber Cement Siding
Good point, the OP never mentioned if it was Hardi or the like.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-02-2009, 02:00 PM   #11
Dorf dude...
shumakerscott's Avatar
Fiber Cement Siding
My previous house had the same siding, with asbestos. You can silicon a couple beads and tape it in place until it sets up, or just use double sided heavy duty tape. Don't drill holes because it can crack the panels. Dorf Dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Tags
cement siding, siding
Siding Options Vinyl vs. Fiber Cement obrien11j Building & Construction 35 09-26-2011 06:08 PM
cement siding over T-111??? jeffnludlow Building & Construction 6 01-29-2009 06:28 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Is this Asbestos Siding or Cement Siding? Pictures inside!!!! twilightcall Remodeling 12 02-01-2008 08:27 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
