-   -   Fiber Cement Siding (http://www.diychatroom.com/f2/fiber-cement-siding-39276/)
pampie 02-27-2009 12:54 PM
Fiber Cement Siding
My home has fiber cement siding and I want to screw an address plaque on it. The sign comes with 2 smallish screws but I don't want to split the siding. Any suggestions?
DangerMouse 02-27-2009 01:13 PM
sure! predrill holes and use plastic anchors such as used for cement block, should hold it fine and not split.
DM
Termite 02-27-2009 03:54 PM
Perfect advice from DM. :thumbsup:
Brik 02-27-2009 04:35 PM
DM advice is good. not much weight. You may actually be fine with just a pilot hole and wood screw. If you have the anchors the do that. If you don't just use the screws and then give a tug, if it doesn't seem secure then get the anchors.
Tom Struble 02-27-2009 09:26 PM
or just use a longer screw
Maintenance 6 02-27-2009 09:54 PM
Don't breath the dust when you drill it. It's likely to be loaded with asbestos.
Termite 02-27-2009 10:21 PM
What? Fiber cement siding does not contain asbestos. :huh:
Tom Struble 02-27-2009 10:37 PM
silica's not good for you either kc
Maintenance 6 03-02-2009 12:25 PM
Depending on the age, it certainly does.
Clutchcargo 03-02-2009 12:44 PM
63 Attachment(s)
Good point, the OP never mentioned if it was Hardi or the like.
shumakerscott 03-02-2009 01:00 PM
Double sided tape
My previous house had the same siding, with asbestos. You can silicon a couple beads and tape it in place until it sets up, or just use double sided heavy duty tape. Don't drill holes because it can crack the panels. Dorf Dude...
