Fed Up With Explosions In Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 07:24 AM   #1
DIY are my initials
Fed up with explosions in basement
I randomly hear an abrupt bang coming from the basement seemingly random. If I'm in the office or sleeping, it can feel it in the house.
1. It is not linked to water faucet usage (an arrestor is installed too)
2. It is not linked to a start cycle of the furnace, nor is it coming from the actual furnace unless the shockwave radiates throughout the ducting
I opened up the furnace and it didn't look excessively dirty.
I hear it maybe twice a day, and I have tried to sit in the basement but it never happens when I'm down there. This will save me some psychological issues in the future and deter the ghost hunter people because a neighbor says my house is haunted
Steelmesh is offline   Reply With Quote
Old 01-08-2009, 08:13 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
What's the age of the house? Could it be the wood "checking"?
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 01-08-2009, 08:34 AM   #3
DIY are my initials
House built in 54'
I did a quick google search, that sounds pretty dang serious because the frequency of occurance is pretty high. I heard a mention of hot/cold cycles, some of the HVAC ducting uses the floor beams, but i'm not sure if that is just the return air ducting.
Old 01-08-2009, 02:44 PM   #4
Learning by Doing
Leah Frances's Avatar
- This weekend put a 3x5 card and a pen in your pocket. Write down every time you hear it happens.
- Hire your kid (or someone else's) to sit in the basement for a day and wait. Hell, I even know some adults who would do it for 50$. You might even get them to do it for free if you toss in the ghost angle.
Happy hunting.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-08-2009, 04:09 PM   #5
I'd sit down there for a free keg of beer. I used to charge a case of beer but I had to go up on my price.could it be related to expansion and contraction caused by the heat of the sun on the house. my house is 7 years old and creaks and pops when the sun comes up and again when it goes down.then again, it's probably just ghosts. if that's the case, I will do it for 2 cases of beer. premium beer, that is.
KHouse75 is offline   Reply With Quote
Old 01-08-2009, 04:18 PM   #6
Happens often in our house. In our case it is a winter-only occurance, and it's due to temperature changes. A loud knock or bang, heard all through the house. Typically happens about 1-3 times / day when very cold, like -10 or lower. Our home is c1989, in the GTA. No worries.
eyeQ is offline   Reply With Quote
Old 01-08-2009, 07:00 PM   #7
K&B Remodeler/Tile Guy
angus242's Avatar
Could be a sump or ejector pump. The last 2 houses I've lived in, both of those pumps bang pretty good when they shut off.
And I assume it's a "bang" you hear, not necessarily an explosion.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-09-2009, 06:55 AM   #8
Depends on what you call loud, but if you can "feel" it I would be worried. We had ductwork that would pop when heat came on, and it was loud, but you could not feel it througout the house. And was unmistakenly a metallic pop. Water hammer is rarely that bad, even in the worst of cases. What kind of heater, water heater??? I would definitely consider a thorough inspection of them.
Old 01-09-2009, 07:07 AM   #9
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
May not be mechanical, could also be structural....
- Build Well -
Old 01-09-2009, 08:56 AM   #10
RippySkippy's Avatar
Water heater bang'n from excess sediment?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 01-09-2009, 07:10 PM   #11
DIY are my initials
Thanks everybody for our replies. I know for sure it is not the water heater, that is another noise and easy to identify when it starts cooking pop corn. Well this morning I was in my office and I felt the bang in the corner of the house. The only thing over there are the heater ducts and I also know of a NG line that runs to a fireplace in the basement. I suppose its the heater ducts...or just ghost monsters punching the heater ducts.
Old 01-09-2009, 07:39 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You'll notice that galvanized heat ducts have a cross or X bent into them. This is for strength and to keep the ducts from flexing excessively. My guess is one of the ducts is slightly tweaked (probably on the top of the duct) and when they expand a few minutes after the heat comes on they pop. Probably striking a floor joist. When it cools it returns to its normal position until it heats up again. May not do it every time the heat comes on.
Old 01-09-2009, 09:14 PM   #13
Sounds like the heat ducts. I grew up in a house built in the early 70s. Whenever the heat would come on, the ducts would pop and tick. When the heat would turn off, they'd do it again. I was used to it but I do remember laying in bed listening to it.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 05:29 PM
