Faux Window Pane Removal? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 09:39 PM   #1
Okay, I'm assuming the answer is no here, but is there any way to remove the hideous faux window panes in new Pella windows? At least I am pretty sure they are Pella, or something similar. The kind that are between the glass...
The previous homeowners updated the front windows and they chose these tacky ones. It's not the end of the world, but I just kind of think the are an eyesore.
erinuncool is offline   Reply With Quote
Old 01-09-2010, 10:17 PM   #2
If they are between the glass then you need to replace either the entire window (maybe cheaper) or each sash window
Window pane replacement help dgbehrends Remodeling 17 11-19-2011 10:06 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Single Hung Window Removal for Drywall bparise Drywall & Plaster 2 12-12-2009 07:44 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
