Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-20-2008, 04:21 PM   #1
Fan question..
I have a regular hampton bay fan with light kit controlled by either pull chain or wall switch. Is there a way to make this fan work with a remote? If so how difficult and what is involled in the install? Thanks
sflamedic is offline   Reply With Quote
Old 03-20-2008, 07:31 PM   #2
electrical contractor
Fan question..
you can buy an add on remote control unit, but you have to take the fan down to install it.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 03-21-2008, 09:55 AM   #3
Crabby Bastard
terri_and_jj's Avatar
Fan question..
you probably won't have to take the fan all the way "down". just loosen the screws that hold the housing on, and let it come down, the fan will still be connected to the mounting bracket, and you can insert the remote module and wire it up. no need to completely remove the fan
terri_and_jj is offline   Reply With Quote
Old 03-23-2008, 11:38 PM   #4
Fan question..
is it a universal thing or brand specific? Does it control the light too? Thanks for the info.
Old 03-24-2008, 02:54 AM   #5
DIY Hack
Mr Chips's Avatar
Fan question..
if you have a hampton bay, you can get one that should fit your fan at Home Depot. will control the lights also
Mr Chips is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
geothermal question robert smith HVAC 2 01-17-2008 09:48 PM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
