Faced Vs Unfaced Insulation In Basement? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-19-2010, 10:01 PM   #1
Faced vs unfaced insulation in basement?
I am finishing out my basement and I put one inch pink board behind the studs. I plan on insulating before drywall but am unsure as to what/ whether I need kraft faced insulation or unfaced insulation. The pink board should be a vapor barrier am I creating a situation where I have two barriers if I use the Kraft faced which I have read is bad? Just trying to get the best scenario. tx
mathias400 is offline   Reply With Quote
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 09:11 AM
do I need to frame my basement insulate with batt insulation? y2chuck Remodeling 3 02-15-2010 08:13 AM
Same old Question basement Insulation advice rp92285 Building & Construction 2 02-05-2010 11:01 AM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
Using rigid foil faced foam insulation Ronnie1a Remodeling 1 01-22-2008 01:23 PM
