Eye Hook Into Brick? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 09:48 AM   #1
Custom User Title
Rewards Points: 252
Eye hook into brick?
I need to install an eye hook into my brick wall of my house for our dog run cable. What is the best way to do this securely? Lead ancor and screw the eye hook right into that?
no1hustler is offline   Reply With Quote
Old 06-27-2011, 10:03 AM   #2
DIY staff
Rewards Points: 7,174
That might work,but the lead might give up because if the constant wiggling caused by the cable.
I'd use epoxy---I am not a masonry guy---let's see what someone else has to say.
Old 06-27-2011, 11:53 AM   #3
Too Short? Cut it Again!
I think you want something more than just a zinc or lead anchor. Some sort of steel expansion anchor that was compatible with the threads on the eyebolt might be a possibility. I guess you could epoxy it all in place but the epoxy is going to have no expansion/gripping properties of its own. And you will have a mess if anything ever breaks on you or you need to replace the fastener for any reason.
I think I would go with some sort of an eyebolt plate I could anchor at four corners. It would cost you a little more and you might need a machine shop to make you something? A marine supply company might have something nice, steel (stainless if you can splurge for outdoor use) and in stock?
Old 06-27-2011, 12:14 PM   #4
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
Why not just sink a post? If you want to get rid of the run, you won't have to worry about patching the brick.
WirelessG is offline   Reply With Quote
Old 06-27-2011, 01:56 PM   #5
Rewards Points: 5,336
They have those corkscrew shaped ground rods that will work.
How big is the dog?
Ron
B. Franklin 1759
Old 06-27-2011, 02:10 PM   #6
Custom User Title
Rewards Points: 252
How big is the dog?
I am making a "trolley" run. It will attach to the house and a tree and the dogs lead will have a pulley that will run on a steel cable. The corkscrew in the ground won't work.
Old 06-27-2011, 02:13 PM   #7
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
I might think about mounting a plate or board of some type to the house with the proper masonry anchors for brick. Then attach the eye hook into the plate/board.
hyunelan2 is offline   Reply With Quote
Old 06-27-2011, 02:25 PM   #8
You'd use 2 corkscrews and a line between them.
Ron
B. Franklin 1759
Old 06-27-2011, 04:03 PM   #9
Custom User Title
Rewards Points: 252
That wouldn't be much fun mowing. It would be a nice trap for the neighbor hoodlums running around the yard in the dark though.
I'm thinking maybe I should just go up to the soffit joist and attach it to one of the 2x's. Assuming it is a 2x attached to the rafter, does anyone see any downside to that?
Old 06-27-2011, 04:56 PM   #10
You'd put the devices just inside the flower beds so it wouldn't be in the way.
You'll figure it out I'm sure.
Ron
B. Franklin 1759
Old 06-27-2011, 04:59 PM   #11
kwikfishron's Avatar
Rewards Points: 598
Originally Posted by oh'mike View Post
I'd use epoxy---
I agree.
kwikfishron is online now   Reply With Quote
Old 06-28-2011, 05:41 AM   #12
Removed the reference.
Ron
B. Franklin 1759
Old 06-28-2011, 08:08 AM   #13
Last post, and the one it references, seem totally out of context for this thread. Did something get scrambled? I don't see any reference at all to nailing marble. I am guessing these made it to the wrong thread somehow?
Old 06-28-2011, 09:16 AM   #14
Custom User Title
Rewards Points: 252
No idea. The only thing I can think of is he is asking a stupid question because I asked a stupid question. Just to be a dick.
Old 06-28-2011, 09:35 AM   #15
the Musigician
DangerMouse's Avatar
"she" was a spammer and was removed.
DM
TV Mount onto Brick Fireplace- Brick Integrity? andrew.volkart Building & Construction 4 03-01-2011 07:21 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
