Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-31-2011, 05:29 PM   #1
Extracting salt from sea water worth it?
I know that salt is very cheap but I know that sea salt is commonly used among the more "experienced" cooks and my guess is that sea salt is probably better for us then plain old table salt. I guess I could just boil all the water out on a stove but that would take alot of energy and not make the effort worth while. What I would do is pour the salt water into a concealed container outdoors that allows the water to evaporate but no bugs or anything to get in. Probably take a while for all the water to evaporate unless its the dead of summer or very very dry air, but its not like it takes any managing from start to finish. Of course the salt would probably end up being a powder instead of crystals so when its ready to use it would just require something a littler different then a normal salt shaker.
From what I read salt water is around 8.5 lbs per gallon and 3.5% salt on average. So looking at about 1/3 lb. in one gallon of salt water. If it turns out to not be that affective then bare minimum it would be an interesting project. Who knows maybe I could end up selling it to people in the area and make a little cash :-)
konsole is offline   Reply With Quote
Old 05-31-2011, 07:02 PM   #2
joed's Avatar
Evaporation is method used commercially.
Also found this info.
Seawater is a natural and easily accessed source of salt. It has salt at an average of 35 parts per thousand. That means that a gallon of seawater has roughly 4.5 oz. of salt in it.
evaporating 3 or 4 gallons of sea water can yield roughly 1 lb. of salt
Do not PM with questions that can be asked in a forum. I will not respond.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 03:47 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Salt water resistant decks stains mlopez Building & Construction 5 09-13-2010 11:14 AM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
