External Opening - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 05:00 PM   #1
Rewards Points: 492
External Opening
Should have noticed this sooner...
Since moving in three years ago we've noticed that our dining room floor (window side) is extremely cold. In our basement, the window near this part of the dining room has a considerable draft. In Dec, I worked on insulating it better until I can replace it. A few days ago, I explored the area on the outside of the house.
I noticed this piece hanging down but never looked closer. (I know. I need to direct the downspout away from the house, another project, especially since I do get some water in the basement)
When I explored further, here is what I saw:
A closer look
I guess this is the foundation of the house. What is the best way to address this problem? Thanks for taking a look!
joetab24 is offline   Reply With Quote
Old 03-06-2010, 05:08 PM   #2
Is this a crawl space area ?
I don't see any insulation up ther
Possible someone enclosed a 3 season porch & never insulated the floor
How big is this opening ?
Old 03-06-2010, 07:38 PM   #3
Rewards Points: 492
Dave, the opening I discovered is to the right of my DR windows. It's not a crawl space. And, as you pointed out, there is no insulation.
Old 03-06-2010, 08:05 PM   #4
Ah ...I see....I'd say there isn't any insulation from the pic
I'd pull it all down & put insulation up there
Then put a piece of plywood back in to close it up
Prime & paint the plywood before you put it in
I'd also consider just closing off the whole area under the window
Maybe brick or something else
Old 03-06-2010, 08:15 PM   #5
Registered User
Rewards Points: 5,514
I'd layer rigid foam insulation between the joists and rigid foam on the bottom of the joists with air sealing for a thermal break, then ply or other cover: http://www.buildingscience.com/docum...n-crawlspaces/ Extend some flat metal flashing to hide the extra thickness and serve as a drip edge, paint to suit.
Be safe, Gary
Old 03-10-2010, 04:27 PM   #6
Rewards Points: 492
thanks for the help....i found another similar opening closer to the front of the house....and I thought I had closed all openings for rodents!
is it necessary to paint the plywood i use to cover the opening, after I insulate it? It's not visible. Is there another reason why painting should be done?
also, GBR mentioned "air sealing for a thermal break"....not sure what is meant by that?
thanks!
Old 03-11-2010, 02:00 AM   #7
Always learning...
fetzer85's Avatar
Rewards Points: 262
Yes, painting it will help keep it safe from the elements - wind, water, etc.
When it comes to insulation, having an air-tight seal is one of the best things you can do. His explanation was just suggesting to create an air-tight barrior to block out drafts and such.
fetzer85 is offline   Reply With Quote
Old 03-16-2010, 04:58 PM   #8
Rewards Points: 492
used some hydraulic cement....plugged the hole up with some steel wool and filled it with cement. not 100%...maybe add some caulk?
Before
After
Space next to window
Filled the hole w/some caulk saver...I am planning on adding some steel wool and then cement...is this the right approach?
Some other concerns.....the more I look, the more I find
electrical wire to addition....is this safe?
this is the exterior area where I think the water is getting into the basement due to some openings and poor grading.
main electrical wire to meter...caulk?
fairly large opening....best way to fill?
lots of flaking and some openings on side of house and at floor level....I have lots of work to do out here
Old 03-17-2010, 06:20 PM   #9
Rewards Points: 492
Just to update and clarify my best course of action.
Some openings on outside of my house.
I know part of my dining room gets really cold in the winter. Sure enough, when I looked outside, I found some openings.
So it seems like in order to do address the cold section of floor....I am going to have to remove the plywood that's there, and stuff insulation up here....not sure how far I will be able to get.
Old 03-20-2010, 07:24 PM   #10
Always learning...
fetzer85's Avatar
Rewards Points: 262
If it was me, I would remove as much as possible to see if it's done right.
For larger, flat areas, you can put up some insulation (spray foam, foam board, fiberglass...) and then attach some painted plywood to seal it in.
For smaller openings, you can use the mortar mix or some spray foam, your choice. Main thing is getting it sealed to prevent draft and critters from getting in your house.
Old 03-20-2010, 08:29 PM   #11
Rewards Points: 492
"If it was me, I would remove as much as possible to see if it's done right."
What would be the easiest way to open this up? As you can see, even though it's open, there are long boards..I am curious to see what's there, or more likely not there.
Getting a furnace through a narrow opening? Sowchoy HVAC 3 02-15-2010 07:55 PM
Putting a wall over a large opening, need ideas aqzman Building & Construction 5 10-28-2009 03:46 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
Opening for attic stairs sk8z Remodeling 16 03-17-2008 12:52 PM
