Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-08-2011, 09:04 PM   #1
Spydey's Avatar
Exterior wall repair help
I need some help in identifying the type of plaster on the wall in the pics. I would also like to know how to do that kind of texturing. Thanks.
Exterior wall repair help-image-4212832987.jpg   Exterior wall repair help-image-1644170308.jpg
Spydey is offline   Reply With Quote
Old 05-11-2011, 12:04 PM   #2
Drywall contractor
Looks like plain old concrete stucco. What I'd call a "skip trowel" effect. Lay down a base coat of stucco, then come back over it with random "splotches" of mud and flatten them out.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-11-2011, 03:48 PM   #3
Spydey's Avatar
Thanks for the info bjbatlanta. Should I use premixed stucco mix or mix my own with Portland cement?
Old 05-11-2011, 04:06 PM   #4
Drywall contractor
Not an expert in this area, but I've used Portland the couple of times I've done stucco repairs. Don't remember the mix ratio of sand and cement offhand, but I'm sure a Google search will get you that info if someone doesn't chime in on this thread with more help....
Old 05-11-2011, 04:53 PM   #5
Spydey's Avatar
Again, thanks for the insite. Much appreciated.
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Drywall repair Transmico Building & Construction 2 11-24-2010 07:17 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
What do you guys think of this roof repair job? darsunt Roofing 7 08-21-2009 09:43 PM
