Extension Ladder Length Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-03-2011, 01:21 PM   #1
DIY Enthusiast
Extension ladder length question
I need to buy a ladder to clean my gutters several times each year and am not sure which length I should get.
My house is a 2-story colonial with 8' ceilings and approx. 22" from ground to 1st floor- so maybe 22ft from ground to gutter?. I'd like to use a stabilizer such that is rests on the roof (just above gutters) because there are too many windows and shutters in the way. I don't want to lean the ladder directly against the gutters.
I can't tell whether I need a 24ft or 28ft.
Thanks for your help!
Ed G is offline   Reply With Quote
Old 10-03-2011, 01:33 PM   #2
kwikfishron's Avatar
Rewards Points: 620
24’ won’t do it you need the 28’ this is the stabilizer I prefer. The one they show on the right side of the page for $30 are a PITA.
http://www.doitbest.com/Ladder+Stabi...sku-779946.dib
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Ed G (10-03-2011)
Old 10-03-2011, 01:41 PM   #3
Rewards Points: 5,336
If you cover the gutters with a guard, you won't need to clean them more then once every 3 years or so. If the house is surrounded by needle bearing trees, a little less.
HD has a guard with a screen covering the small holes. It does a good job even with needles. Case of 25, 3 ft sections was about $45.00.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Ed G (10-03-2011)
Old 10-03-2011, 02:01 PM   #4
DIY Enthusiast
Good point about the gutter screens. I've heard mixed reviews on all varieties, but think I'll get a couple sections to try out this year and hopefully reduce the cleaning frequency.
Old 10-03-2011, 02:05 PM   #5
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Get a sturdy ladder at that height. THe Werner Black-Tip can't be beat.
Only 56#. http://www.industrialladder.com/prod...productID=2782
Some Hardware type places will let you try some for comparison. The Red, green, yellow tipped ladders for instance can be very wobbly and scary at 20'. THe black tip will feel as sturdy as a staircase.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Ed G (10-03-2011)
Old 10-03-2011, 02:12 PM   #6
DIY Enthusiast
That stabilizer looks more secure (attaches to 2 rungs). What makes the other a PITA?
Old 10-03-2011, 02:21 PM   #7
Pro Slate Roofer
tinner666's Avatar
The one in the link is Werner's Kwik-Klik. Easy on, easy off, and can be dismantled for storage. No tools needed.
Ed G (10-03-2011)
Old 10-03-2011, 03:43 PM   #8
I've gone through about 6 different varieties over the years. I put the latest version on in 1992. It's been on the house for 19+ years. I clean the gutters every 3-4 years. Last year I noticed a few cracks in some of them. I'll replace them next spring.
The first 6 months in the house I had to clean the gutters 3 or 4 times due to all the trees.
Ron
B. Franklin 1759
Old 10-03-2011, 07:44 PM   #9
DIY Enthusiast
Ron,
Are THESE the ones you're talking about? I saw them in the store and thought they looked pretty nice.
Old 10-03-2011, 07:45 PM   #10
Rewards Points: 150
You should not of cut all your trees down...
OhioHomeDoctor is offline   Reply With Quote
Old 10-03-2011, 09:35 PM   #11
Ron,
Yes, those are the ones.
Ron
B. Franklin 1759
Old 10-03-2011, 09:36 PM   #12
What are you referring to?
Ron
B. Franklin 1759
Old 10-04-2011, 09:30 AM   #13
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
Not to hijack here, but ladder tip colors mean something? I thought they were just ornamental. What do the colors mean?
Also, FWIW, I live in the woods and have the screen type gutter covers and they still get clogged with leaves and debris. I clean twice a year and still end up with plants growing in the silt that collects in my gutters. Plus, when the screens are covered in leaves the water just goes right over them to the ground. I'm not saying they don't help, but when you have lots of trees nothing is going to keep your gutters perfectly clean. Fortunately, I live in a one story ranch and can reach my gutters by climbing on the roof with my Little Giant ladder
Oh-Fudge is offline   Reply With Quote
Old 10-04-2011, 07:07 PM   #14
Pro Slate Roofer
tinner666's Avatar
The colors have to do with identifying weight restrictions, service use, etc.
Climb a 300# rated Blacktip fully extended to 40' and then try a red tip, for instance in it's closed position and the difference will be evident. Extend it any and plan on a balancing act as it wobbles around under you. The wobble will fell like 1' to 2' swings!
Oh, I forgot, the feet have must better positioning positions with a blacktip and better grip than you'l ever find on the others. And, it snaps apart easily if you only need 1/2 a ladder, and easily back together. Like their Kwik-Klik.
Old 10-04-2011, 07:39 PM   #15
tinner, is this a specific manufacturer designated rating? I'm used to seeing ratings on a ladder based on weight, not color.
Ron
B. Franklin 1759
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 09:30 AM
total effective length question drewhart HVAC 2 01-27-2009 08:46 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Extension Cord Question. camoram Electrical 2 04-08-2006 09:12 PM
