Extending Height Of Deck Railing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-08-2008, 09:38 PM   #1
Extending height of deck railing
The railing on the deck that I am working on is currently 36". THe problem is that the floor of the deck was set way to low for the entrance into the house, resulting in the need to put in steps to go into the house and the railing does not meet code now because when you are at the top of the steps you can fall over the railing. Without completely re-doing the railing, how can I extend the height of it without using something tacky like lattice? The railing consists of medal ballisters with the typical 4x4 posts with toppers and a 2x4 top rail. I was thinking of just adding another subsection of this very same thing to extend the height but was not sure if there were any other ideas and how someone out there dealt with this same issue.
Thanks!
tntworks is offline   Reply With Quote
Old 02-09-2008, 06:33 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Pictures of the area and the railing system would really help.
- Build Well -
Old 02-10-2008, 11:37 AM   #3
Rewards Points: 528
Why can't you install a railing for the steps. A picture of the entrance to the house would help. It does not seem logical to raise the height of your deck railing.
rjordan392 is offline   Reply With Quote
Old 02-26-2013, 08:56 AM   #4
Roofmaster
Rewards Points: 2,172
You cant use a 2x4 on the flat for a railing either, from what I understand. You have to be able to get your hand around it. Makes sense if you think about it. How about 1.5 inch pipe attached with floor flanges, prime and paint to match house?
Old 03-11-2013, 07:16 AM   #5
greetings from Bolivia
harrymontana's Avatar
Send a message via Skype™ to harrymontana
I would just use the same railing and get some new lattice to increase the height. Otherwise you will end up with two sets of some kind of railings??
harrymontana is offline   Reply With Quote
Minimum Deck height? sandyman720 Building & Construction 16 01-29-2008 11:12 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Top Cap on Deck Railing cibula11 Building & Construction 5 07-25-2007 06:17 PM
Deck Height w/out step DLP600 Building & Construction 4 04-19-2007 11:34 AM
Deck Railing ? JayI Carpentry 6 09-09-2006 01:37 PM
