Excessive Window Leaks - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-12-2010, 12:36 PM   #16
Newbie Bill
Rewards Points: 520
Originally Posted by diy4life View Post
My windows insulator - the rubber and fuzzy lines that runs along the window edges are falling out and hanging and about to fall off. My guess is that my windows probably are older than 20 or even 30 years old.
Could you possibly post some pictures of your windows?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 02-12-2010, 01:37 PM   #17
Rewards Points: 5,336
Originally Posted by drtbk4ever View Post
diy4life,
Maybe someone with some knowlege will give you some input on putting money towards new furnace versus new windows. Maybe the payback would be greater with new windows. I personally don't know the answer to that question.
Regardless, please let us know your progress and what you decide.
The payback will vary, house to house based on it's overall envelope. I think older houses will see a greater payback on energy savings by upgrading the insulation and windows then a better heating plant. Unless you can contain the heat in the house, the diffference between an 80-90% upgrade will be minimal as the heat will still be lost at the same rate as before the new unit was put in.
If you're doing both projects close together, the difference is inconsequential. If they'll be done years apart, I'd button up the house first.
Ron
Old 02-12-2010, 06:02 PM   #18
Rewards Points: 93
Originally Posted by jlhaslip View Post
Are they single pane glass or double pane?
Where are you located?
Please update your location in your Profile.
My windows look like double pane, but they are very close to each other. I think they are only half an inch gap between them.
I live in Pittsburgh, PA. Sometimes it gets really cold here.
Life is tough, but it is even more tougher when a person is stupid.
diy4life is offline   Reply With Quote
dormer window leaks billygne1 General DIY Discussions 6 03-28-2014 04:52 AM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
