Even Flooring HELP!!! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-15-2015, 03:14 PM   #1
Rewards Points: 2
Even flooring HELP!!!
Hello, I am having trouble with uneven hardwood floor (due to uneven subfloor, see image). Any suggestions on how to fix this issue?
jackal813 is offline   Reply With Quote
Old 09-15-2015, 03:23 PM   #2
Rewards Points: 5,336
The solution would have been before the finished floor was put down. You're not fixing the floor at this point, but you can mask the mistake.
Pop off the saddle between the wood and tile. Install the new saddle higher on the left side of the photo so the floor lip is hidden. There will be a higher side to the saddle, but that's the cost of after thought remedies. It will be less obvious then the floor.
To minimize the tripping hazard, use a Hollywood saddle made for the space.
Ron
B. Franklin 1759
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
removing laminate flooring mikeinMemphis Flooring 24 02-24-2013 09:06 PM
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 12:21 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
