Even Door, Uneven Gap - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 08:21 PM   #1
even door, uneven gap
We have an exterior door that is level and the frame is not. The door is rubbing in top corner of lock side and bottom corner of hinge side, with gaps on the opposite corners. We are pretty sure ur whole house is not level. How do we go about fixing this?
bkdsferber is offline   Reply With Quote
Old 03-22-2013, 08:40 PM   #2
Rewards Points: 12,856
Got a picture to post to use to make suggestion.
What do you mean the doors level? Do you really mean plumb? Plumb would be vertical.
Is it wood, metal?
Checked for a stripped or loose hindge screw?
Used at least a 4' level and a framing square to check. hindge side jamb, the head jamb, and threshold?
Old 03-22-2013, 08:42 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,.... 1st thing to do is figure out Why, 'n Where yer house is Movin'....
Foundation Failin',..??
Sinkhole,..??
Old 03-22-2013, 08:44 PM   #4
Termites, wood rot under the threshold?
Old 03-22-2013, 09:32 PM   #5
DIY staff
Rewards Points: 7,174
loose top hinge? Run a long screw instead of one of the short ones---2 1/2 " of longer---that will pull the top back where it belongs.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
kwikfishron (03-22-2013), mj12 (03-23-2013)
Old 03-22-2013, 09:35 PM   #6
Might want to go back and check that idea agin Mike.
Sounds like the screw needs to go in the bottom hindge instead.
Old 03-22-2013, 09:54 PM   #7
Rewards Points: 2,630
I think Mike has it right.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
oh'mike (03-23-2013)
Old 03-23-2013, 08:24 AM   #8
Lord of Slums
Rewards Points: 1,974
Firmly grab the door and lift and push, he may have a bad hinge.
mj12 is offline   Reply With Quote
The Following User Says Thank You to mj12 For This Useful Post:
Old 03-23-2013, 12:45 PM   #9
greetings from Bolivia
harrymontana's Avatar
Send a message via Skype™ to harrymontana
vertical post is expanding while the horizontal is not?
maybe your entire house is twisting, anyway, I would just fix the problem by planing where the door is tighthened. You can find the exact location where to plane by rubbing some peanut butter or other liquid and close the door and when the liquid is gone, this is the spot you need to plane.
harrymontana is offline   Reply With Quote
Old 03-23-2013, 05:51 PM   #10
Natineah's Avatar
It can be that. Mike needs to check it and confirm it,bad hinge can be done by yourself.
Natineah is offline   Reply With Quote
Old 03-23-2013, 06:07 PM   #11
Lord of Slums
Avoid those big box store hinges. The best big box store hinges are completely unacceptable at best.
