Epoxy Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-07-2011, 09:48 PM   #1
Epoxy Question
I have a Nordic Track Ellipse elliptical machine (I believe it's the e9, but if it's not, it looks very similar to it). The metal a couple inches behind the right, plastic foot pad, just under the big plastic cover, has torn asunder. I was wondering: Does anybody know of an appropriate epoxy that might adhere this back together and allow me to use my elliptical once again? Also, how would you apply it?
the_joey_o is offline   Reply With Quote
Old 02-08-2011, 07:47 AM   #2
DIY staff
Rewards Points: 7,174
Picture??????????
Old 02-08-2011, 09:23 AM   #3
Originally Posted by oh'mike View Post
Picture??????????
Ok. Here's a close up and one a bit further back so you can see the elliptical.
Old 02-08-2011, 10:03 AM   #4
Experienced
Jackofall1's Avatar
Not sure about epoxy, but did you try writing the manufacturer to see if you could get a replacement part for that?
That looks like a stress crack in white iron (cast aluminium / magnesium) which I am sure will need reinforcing, not just glued back together.
Mark
Old 02-08-2011, 10:04 AM   #5
DIY staff
If the metal has cracked from fatigue---epoxy will not be the answer---welding or brazing would be the best solution---check with a local welding shop or a bicycle shop--(my local bike shop used to be a good place for this sort of small repair.)---Mike--
Old 02-08-2011, 10:28 AM   #6
Ok. I'll do that.
Tags
elliptical , epoxy help
Old paint on concrete question? Sellncars Painting 2 04-18-2009 08:46 AM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Epoxy roof sealant over shingles? P550 Roofing/Siding 15 04-11-2009 11:00 PM
epoxy coat and resurfacing concrete cure time questions ?? waltereo Flooring 3 10-04-2008 12:43 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
