Entry Door Knob Help Needed - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-19-2012, 05:21 AM   #1
Rewards Points: 1,192
I put a entry key type door knob in my garage to gameroom door that is loose. I can't figure how to remove the knob to tighten the screws up.
bobelectric is offline   Reply With Quote
Old 08-19-2012, 11:55 AM   #2
Rewards Points: 13,296
If the screws are exposed you do not have to remove the knob. Just need a #2 phillips screwdriver.
If there's a cover plate there will be a small rectanguler sopt on the side that you just use a small blade flat screw to push in on the little tab and it will pop off.
Anytime you can post a picture you will get more ansewers and less questions.
Old 08-19-2012, 02:43 PM   #3
Thanks Joe . can't figure out how to remove doorknob,ready to get my sawzall.
Old 08-19-2012, 04:09 PM   #4
Bob,
This should give you a pretty good idea of what to do,
VIPlumber is offline   Reply With Quote
Fan size needed for Spray Booth (CFM) Sandy 1150 Painting 0 12-21-2011 08:22 PM
Building a 20' x 20' wood frame garage bgbrown125 Building & Construction 38 08-07-2011 02:53 PM
Face nail needed with Bona r851? bakerzdosen Flooring 0 08-01-2011 08:56 AM
Need advice on quantity of primer and paint needed laurat Painting 8 01-01-2011 11:53 AM
Combustable air, how much is needed? Lee Roy HVAC 9 10-27-2010 11:17 PM
