-   -   Entry Door Knob Help Needed (http://www.diychatroom.com/f2/entry-door-knob-help-needed-154157/)
bobelectric 08-19-2012 04:21 AM
I put a entry key type door knob in my garage to gameroom door that is loose. I can't figure how to remove the knob to tighten the screws up.
joecaption 08-19-2012 10:55 AM
If the screws are exposed you do not have to remove the knob. Just need a #2 phillips screwdriver.
If there's a cover plate there will be a small rectanguler sopt on the side that you just use a small blade flat screw to push in on the little tab and it will pop off.
Anytime you can post a picture you will get more ansewers and less questions.
bobelectric 08-19-2012 01:43 PM
Thanks Joe . can't figure out how to remove doorknob,ready to get my sawzall.
VIPlumber 08-19-2012 03:09 PM
Bob,
This should give you a pretty good idea of what to do, http://www.youtube.com/watch?v=Pgdm88cTxlU
