Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-28-2005, 06:06 PM   #1
Smile
Entertainment center
I am attempting to build a TV stand and eventyally an entire entertainment center for a 42 inch TV. I am needing guidance on what type of joint method would be the best. I have spoke with several people and the majority of them say to use dowel joints. Is this the best method or are there other sugestions. i just want to be sure that my TV does not end up on the floor. Any advice would be appreciated.
Thanks,
Mike
baldeagle51 is offline   Reply With Quote
Old 08-28-2005, 10:55 PM   #2
Contractor
There are a few ways to go about this. I generally use dado's and superb glue. I'm also assuming that you are planning to use cabintry grade wood and not some MDF or particle board junk.
For support, I usually use cleats beneath the shelf. One across the back, one spanning the center and rabbit in the front one. With a 42" set, you can also include a center upright and ajustable shelving to hold all of the rest of your gear.
Teetorbilt is offline   Reply With Quote
Old 08-30-2005, 08:25 AM   #3
Thanks for the advice, that gives me a starting point. Im new to woodworking and trying to figure out the best way to build things. Its easy to slap somethig together but to build something that lasts is a different story. I appreciate all your help
Thanks,
Mike
Old 09-02-2005, 11:02 PM   #4
I will be using 3/4 inch wood. How deep do you cut your dado's?
Old 10-02-2005, 10:05 PM   #5
2pyrs
Thanks,
Mike
I made an entertainment center 8 foot long by 8 foot high and used only dry wall screws and no glue or dado cuts. It held 27” TV and 10 gallon fish tank on bottom shelf. Was around for 4 years and did fine.Most of the work was in making the design.
2pyrs
2pyrs is offline   Reply With Quote
Old 10-04-2005, 01:54 PM   #6
Tired, Cold, and Damp
slickshift's Avatar
Hmmm...
A few years ago I built a corner entertainment center for a customer with just a framing saw
Dado cuts and all
lol
The guy still uses it, he loves it
I'd also like to know how deep Teetorbilt recommends
slickshift is offline   Reply With Quote
Old 10-04-2005, 04:43 PM   #7
Contractor
I dado to about 1/3 of the thickness of the board +.
A little trick: Set your dado depth so that the measurement from the bottom of the groove to the outside of the board is a common measurement. This helps when working with todays lumber and ply which now comes in metric and goofy sizes.
Say you're making a 3ft. long shelving unit from 3/4" ply which is really 23/32". Dado the shelf end pieces so that the bottom of the groove to the outside of the board is 1/2". Now cut your shelves to 35" and when assembled, the unit will be 36" overall. You have also skipped over trying to figure out what 1/3 of 23/32" is and how long to cut your shelves.
Old 10-04-2005, 11:34 PM   #8
slickshift's Avatar
Thanks man
Great tip!
My Custom In-Wall Entertainment Center Project! With lots of photos!! joseph011 Project Showcase 12 01-03-2011 02:43 PM
Entertainment Center Help in Chattanooga TN bemgolf Home Theater 1 07-18-2007 11:29 PM
panel home, nothing seems to be 16 on center johnny331 Remodeling 4 06-30-2007 08:56 AM
Drilling into Center Beam leted_82 Building & Construction 2 03-06-2007 09:52 PM
Load Center dwayne Electrical 4 07-09-2006 02:02 PM
