Elevator Doors For A Production Set - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-27-2009, 06:03 PM   #1
Elevator Doors for a production set
Hey I need to make a frame with 2 ,30 inch wooden doors that open like elevator doors. It will be used a lot during the production. I bought a sliding door track to use. I would like to be able to pull one door and the other door open equally using a pulley system. Any ideas. Please Help!
jdonald is offline   Reply With Quote
Old 05-28-2009, 12:05 AM   #2
The simplest would be to attach the rope to the inside top of one door and run threw a pulley past the farthest opening of the opposing door and to the outside edge. This will make the one pull away at the same time. This would also have to be done for the other door so it would not matter witch door you pull open or closed. the trick will be keeping the ropes or cables from running into each other. I would suggest making some brackets off the backside so you have more room to attach. I would suggest hang to door on the same long track and make unit work before fixing into your set. Also maybe use a rubber pad or gradge door bottom wether stripping to help soften the closing
Mgmopar
MgMopar is offline   Reply With Quote
Old 05-28-2009, 11:51 AM   #3
thank you
Thanks so much I can't wait to build it.
Old 05-28-2009, 01:04 PM   #4
Old School
Willie T's Avatar
Interesting.
Old 05-28-2009, 01:47 PM   #5
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Star Trek
Is this for a follow up Star Trek series? You would need air actuator to make them open and close fast!! Dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Tags
elevator doors , please help , pulley genius
