Electrified Rain Gutter - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-27-2010, 01:59 PM   #1
Metalman
Electrified rain gutter
Just something I'd like to pass on. I once got a jolt from a friend's gutter downspout. We put a meter on it and got 90 volts to ground! The contractor that put up the gutters must have driven a nail into the supply to his outdoor spotlights, because after turning off breakers one at a time, we isolated the problem. The contractor said "I've never had this problem before!" but fixed it.
Metalman
dave1123 is offline   Reply With Quote
The Following User Says Thank You to dave1123 For This Useful Post:
Tom Struble (08-27-2010)
Old 08-27-2010, 02:38 PM   #2
Originally Posted by dave1123 View Post
got a jolt
90 volts to ground!
This problem has come up before.
Why wasn't it 120 v?
Was the jolt a "tingle" [~1 mA] or "painful" [over 10 mA]?
Were your hands dry?
Were you wearing sneakers or leather shoes?
Thanks for any addt'l info. This will come up again, along with people being shocked in swimming pools.
Old 08-27-2010, 02:49 PM   #3
Rewards Points: 472
On the voltage the minus side wasn't a good ground . Like a copper rod down 8 feet or more for a good ground. I used to check my ground's on my ham radio antenna's. What i would do is use the plus or the hot leed and measure with a volt meter and see what voltage you get. I live in florida and sometimes a 8 foot wouldn't be enough to get the 120 volt's or what the voltage out of the wall outlet was. Sometime i would have to couple two eight foot copper clad rod's togother and drive them all the way down. Than the voltage was equal to the wall outlet. Probly what he was getting was very little amprage. More like a tingle . Now if you had a meter to measure the ma. That would have told you what the current was. I was in radio and tv repair so i know a little about shock's
del schisler is offline   Reply With Quote
Old 08-27-2010, 02:58 PM   #4
And with flat screen TVs there is no more CRT 2nd anode to zap you!
Old 08-27-2010, 03:03 PM   #5
Rewards Points: 472
you need a little zap once in a while . Just to let you know what not to do the next time. But those old metel pic tube's used in the rca was the worst ones even when you discharge them . they would still get you when you had to change the tube up in the tuner. Those were the day's Been retired for 20 ysr now But was in tv repair for 40 yrs thanks for the reply del
Old 08-27-2010, 07:16 PM   #6
Rewards Points: 276
I can remember thinking I wanted to be a TV repairman when I was young.
Even took a class offered in high school. Nowadays people just throw them out and buy new.
Jim F is offline   Reply With Quote
Old 08-27-2010, 07:55 PM   #7
Metalman
The ground was only a chain link fence nearby. It was just a tingle, until I put my hand on the fence! Then it was enough for me to jerk back and go "What the hell?"
Hey TV guy. Do they use flat screens in radar displays yet? Those CRTs were nasty!!
Metalman
Old 08-27-2010, 08:08 PM   #8
Well, ~20 mA is the 'can't let go' threshold so I guess you got around 10 mA.
90 V/0.01 A = 9000 ohms so you probably had dry skin but the voltage might have been lower because you might have been loading down. Maybe you got 30 V @ 10 mA @ 3 K skin/body resistance.
The concrete that the fence posts are sunk in, and the ground, and you, are semiconductors.
Some TVs used 5U4 rectifiers in the power supply and if you shorted the supply the plates would slowly turn bright red. Great fun!
I might still have my RCA Tube Manual. My Knight Kit VTVM still works. . .sort of.
Old 08-27-2010, 09:05 PM   #9
Tom Struble's Avatar
Rewards Points: 2,002
ok ok your getting way too excited...drink your milk and go to bed
Tom Struble is offline   Reply With Quote
Old 08-27-2010, 09:12 PM   #10
OK, as soon as I get done singing along with my oldies on YouTube.
Or, if you like "Popera"
The Following User Says Thank You to Yoyizit For This Useful Post:
Tom Struble (08-28-2010)
Old 08-27-2010, 09:12 PM   #11
Rewards Points: 472
I had so much fun going on a service call in the wenter when it was zero and than you needed to take the chassis to the work shop Sure was a bunch of fun. Like hell it was Done that for 40 or so yrs. Don't miss it . Retired and now work in the wood shop
Old 08-27-2010, 09:18 PM   #12
In '94 I found out the hard way that hand surgeons in DC charge up to four kilobucks per hour. They don't like sewing things up that they need a microscope to see. Keep the guards on.
For $50K my hand works, sort of. . .
Gutter installation questions Homerepairguy Roofing/Siding 7 03-15-2012 10:22 AM
Rain gets underneath gutter Heimwerker Roofing/Siding 8 12-28-2011 12:59 AM
Rain gutter slopes the wrong way ovahimba Roofing/Siding 2 12-20-2009 03:56 PM
"Frozen" Gutter Leak cougar01 Roofing/Siding 19 02-10-2009 06:07 AM
