Electrical ? Re: Pop And Trip In Light Switch - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-09-2011, 08:35 PM   #1
Sld
Electrical ? Re: pop and trip in light switch
Hi,
I am new to the chat room. I have little electrical experience, just a few switch replacements, lights, fans. My daughters' light switch (combo light & fan) just popped and then tripped the switch. Should I be able to just put in a new switch or is this potentially dangerous and should I call in an electrician? Never had an electrical pop before ........
Thanks very much
Sld is offline   Reply With Quote
Old 10-09-2011, 11:50 PM   #2
Rewards Points: 1,092
First, I'd take both appliances apart and look for a short. It sounds like a hot wire is touching ground. Wires come loose, fray through, get accidentally pinched under something, or rodents eat at them. Switches sometimes short internally, too. Good luck. j
Old 10-10-2011, 06:28 AM   #3
What he said, but with the power off, it should be safe to work on. If you have any doubts, call a pro. The part that 'popped' should be easy to spot, you will see burn/flash marks. You said it was for a fan. Look in the canopy under the fan with the switches. The capacitor that gives the motor the 3 speeds is often a culprit. It is usually a square block with 3+ wires comming out of it.
Old 10-10-2011, 10:05 AM   #4
Sld
Thanks very much
I had a loose neutral wire and it blew out the switch. Getting a new one today to replace tonight.
Thanks again, much appreciated!
Old 10-10-2011, 12:14 PM   #5
Rewards Points: 5,336
Originally Posted by Sld View Post
Thanks very much
Loose neutrals do not cause short circuits unless they touch the hot wire.
Ron
B. Franklin 1759
