Electrical Outlet And Light Switches HOT - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 02:44 PM   #1
Question
Electrical Outlet and Light switches HOT
Hello,
Just had a problem where my 15 amp outlet just blew. So I went and replaced it with another 15 amp outlet and now every outlet in the room is hot. I should have one outlet in each on switch only. Not sure what I am missing. I know it is an easy fix just not sure where.
Thanks for any help you can provide
MicahDog is offline   Reply With Quote
Old 01-10-2010, 02:59 PM   #2
Rewards Points: 5,336
Originally Posted by MicahDog View Post
Hello,
What do you mean the outlet "blew"?
"I should have one outlet in each on switch only." What does this mean? Is every outlet controlled by a switch?
Ron
Old 01-10-2010, 03:02 PM   #3
Most likely you had one 1/2 of that outlet controlled by the switch
Usually this means the hot side the little tab is broken off between the screws
Take a look at the old outlet
Or you wired something wrong
Old 01-10-2010, 03:59 PM   #4
Yep thanks it was the tab. I wish they would put that somewhere on the box.
thanks
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
adding outlet from light switch tad Electrical 17 06-05-2009 11:25 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 12:53 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
