Electrical/Drywall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-08-2010, 12:23 AM   #1
Electrical/Drywall
If you have happened to cover up an electrical outlet with some drywall, is there any way to find the outlet?
newguy220
newguy220 is offline   Reply With Quote
Old 02-08-2010, 12:30 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if the sheet rock hangers did it, I usually find a big hammer does the trick. Liberally applied to the wall in a non-distinct pattern usually results in the rockers finding the box after about my second hit.
If it is my fault, there are several things that will help.
do have an idea where it is? the box will cause a bulge in the rock. It also makes a hard spot where the box is.
Old 02-08-2010, 06:22 AM   #3
Too Short? Cut it Again!
Find your stud spacing and locate other outlets in the series. The hidden outlet is probably somewhat equal spaced and attached to a stud between other outlets?
For next time, this system saves a lot of time.
http://samplerewards.com/index.cfm?f...roduct_ID=2136
Old 02-08-2010, 10:48 AM   #4
Phone toner works.
Make sure the power is off.
Power Tech is offline   Reply With Quote
