Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-19-2013, 06:17 PM   #1
Electrical appliances all stopped working
My furnace, dryer, stove, and garbage disposal seem to all simultaneously quit working at times. I flip the breakers on and off. Nothing happens. When I press the "start" button on the dryer, the furnace hums. The last two times this had happened everything eventually kicked back onon on their
jjacobson8 is offline   Reply With Quote
Old 03-19-2013, 06:19 PM   #2
Own. Now not so much. None of these appliances are on normal outlets. And we did get a new dryer. But it's a high efficiency.
Old 03-19-2013, 06:27 PM   #3
PoleCat's Avatar
Is your breaker panel outside? Sounds like you are getting an intermittent drop on one of you legs.
PoleCat is offline   Reply With Quote
Old 03-19-2013, 06:29 PM   #4
Electrical Contractor
Have the poco come out and look for a loose connection to the house.
You have a typical loose connection to one leg of the service.
It could be at the weather head, the meter or the panel.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-19-2013, 06:45 PM   #5
The breaker is on the inside. So there is no easy fix. I have to have someone come out and check the legs?
Old 03-19-2013, 06:48 PM   #6
We have had strong winds today...
Old 03-19-2013, 07:47 PM   #7
Call them asap and and unplug everything you can.
Do not keep trying to check anything to see if it will run until this is fixed.
Got a meter and know how to use it?
Old 03-19-2013, 07:57 PM   #8
Got one. Don't know how to use it
Old 03-19-2013, 07:59 PM   #9
Unplug everything? Can I just flip the breakers to off?
Old 03-19-2013, 08:00 PM   #10
That will work.
Coaxial Jack STOPPED working? JayNYOne Electrical 4 12-11-2011 11:20 AM
Sockets stopped working-need electrical advice suspal Electrical 18 12-08-2011 12:29 PM
VERY EERIE! Remote garge door openers and both car remotes stopped working! proofer Automotive Repairs 12 05-03-2011 09:29 PM
Furnace stopped working? kcrossley2 HVAC 2 01-12-2011 08:45 AM
Garage door keypad stopped working bklyn1028 General Discussion 7 02-17-2010 08:32 AM
