Electric Sump Pump Lubricant - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-26-2009, 09:24 AM   #1
electric sump pump lubricant
Does anyone know the type of oil used for lubrication inside a sump pump?
bbplayr2 is offline   Reply With Quote
Old 08-26-2009, 01:08 PM   #2
Rewards Points: 6,652
Unless it states that it can be maintained, majority of the units use sealed bearings, and are toss aways when they go bad.
Old 08-26-2009, 05:24 PM   #3
Household Handyman
Rewards Points: 1,408
bbplayr2--I'm playing a hunch here: Are you talking about the type of sump pump where the electric motor part is oil filled? I'm familiar with these type in Industrial settings but not in homeowner types. The oil in these would be for motor cooling purposes, not lubrication of the bearings. These are generally sealed units, and if the oil level should become low, then there is a leak somewhere which would require the unit to be properly serviced. I do know from one of our "electricians" at work some years back: DO NOT use motor oil. It is NOT dielectric and will cause the motor to go BOOM! big time when bench tested, as he did. gregzoll is correct as far as the bearing in most homeowner type sump pumps, they are indeed sealed. I hope this helps, David
Old 08-27-2009, 07:44 PM   #4
Idiot Emeritus
Rewards Points: 1,492
Transformer oil. The same stuff they use in oil-filled transformers. Highly dielectric, low lubrication properties, but excellent heat transfer.
Most motor shops either have it or can get it.
Rob
micromind is offline   Reply With Quote
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
