Electric Pump Placement For Irrigation System - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 07:58 PM   #1
Electric pump placement for irrigation system
Building a new home and builder runs the 220V line just inside the crawl space for well pump placement. Should I have it run to put pump in the garage or leave it in the crawl? Concerned about not being able to detect a leak.
birklund is offline   Reply With Quote
Old 01-16-2011, 09:02 PM   #2
Rewards Points: 6,652
Where are you located? Keep in mind, that if you are in a cold climate area, the pump & associated piping will freeze in a Garage. Also, you will know when the pump is running or not. If it runs continuously, and no valves are open anywhere in the house at sinks, tub, shower, toilets, yep you may have a leak.
Dry sump pump pit/failing septic system Jenn M. Plumbing 4 01-08-2010 10:01 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 07:13 PM
Electric Wiring for Pool Heater (heat pump) tazmajazz Electrical 7 10-21-2009 09:49 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Replacing Heat Pump system - Carrier or Rheem? CoolMan74 HVAC 6 06-28-2009 11:13 AM
