Electric Motor Blues...... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-29-2011, 06:52 PM   #1
Rewards Points: 1,062
electric motor blues......
Pulling my hair out- OK, take a basic motor, say, you have to remove the commutator to put in new brushes. Now, popped in the brushes back but the coil springs behind them prevent me from dropping the motor commutator/shaft down in there with springs "compressed". Enter the surgeons pliers.
tried squeezing the 2 springs that are on opposite sides, of course, with surgeons pliers (actually keeping the pliers open so the tips are open wide, thus keeping the brushes/springs farthest apart. With that, I slowly drop in the shaft/commutator but only so far until the angle is so sharp relative to the pliers' tips, that the surgeons pliers slip off, and hence, the springs/brushes also go booooooiiiiiing and pop out preventing the shaft/commutator from dropping down neatly.
Sheesh. Whats the trick, electric motor guys??
Thanks!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 11-30-2011, 06:06 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,.... Usually there's holes in the brush holders that you slip a wire through to hold the brushes back...
When the shaft is In, ya pull the wires out, 'n the brushes contact the shaft...
Bondo is online now   Reply With Quote
Old 11-30-2011, 06:50 AM   #3
No holes as the motor "case"(?) covers the entire outer surface around the coil/commutator innards. That would have been a nice feature for this challenge, but no such luck. Buy thanks for trying, Bondo. Im still searching for the secret.
Old 11-30-2011, 06:51 AM   #4
tis is a picture of the motor (its from a GM 80's car), for headlight doors....
http://www.autopartswarehouse.com/de...d=P1135867996W
Old 11-30-2011, 07:32 AM   #5
Rewards Points: 3,130
I suspect something as inexpensive as that was not designed to be repaired.
Old 11-30-2011, 11:42 AM   #6
Rewards Points: 120
Clicked on your link, so have an idea of what you have, but can't quite make out the details. Could you tie the brushes back, like with a piece of fishing line, then cut and pull it out once everything is in place?
Old 11-30-2011, 01:47 PM   #7
You know, Dex, thats a good idea! I was thinking of bread wrapper twist ties, but that wouldnt be "nimble" enough. Gonna try it!
Old 11-30-2011, 01:48 PM   #8
Wrong- happens all the time. Just gotta figure how. These are original solid GM motors, Made in the USA- a rare thing these days. lasted so far 24 years. Those for sale on that link I bet are China JUNK.
I dont do stuff only if its easy. But thanks just the same, MD!
Old 11-30-2011, 02:28 PM   #9
Rewards Points: 120
Another thought, which I sort of doubt will work, as the spring is different, but I had one of my older power tools apart just a few weeks ago, and was able to get the springs to catch off-center just enough that they were compressed against a couple of landings, rather than the brushers, so that I was able to slide everything back together and then poke in there and work them back into place. Again, probably not the solution in this case, but maybe it will inspire a thought when you look at it.
The Following User Says Thank You to DexterII For This Useful Post:
noquacks (11-30-2011)
Old 11-30-2011, 03:57 PM   #10
Rewards Points: 282
sometimes you can compress and tape them over (tape over the brush/spring holder hole) and then use a thin razor blade (if needed) to lift the tape off once assembled, and let them pop into place.
can you take a pic of the actual inside so we can see?
jcrack_corn is offline   Reply With Quote
Old 11-30-2011, 04:09 PM   #11
Thnaks, but Im bad at pictures. Going out in the ccccccold garage now (its 65 degrees F out there today....LOL)
Old 11-30-2011, 04:27 PM   #12
Im back- FISHING LINE IDEA WORKED!!!!!!!!!!!! Yes, it was a little finicky, especially with cold fingers out in 60-65 deg garage, but worked like a charm!
Trickiest part was how low one could lower the case- low enough to keep the brushes on the commutator "band", yet high enough off the base to allow one to slice the fishing line with a craft knife, and pull it out slowly so as not to break the line. Cut/shards of Fishing line is bad for turtles/pelicans/other sealife, and also bad for motor innards.....LOL
Thanks, people!
Old 11-30-2011, 05:17 PM   #13
Rewards Points: 120
Good for you! Glad it worked. Now, as for cold, my shop is a good 30 degrees or more below that this evening, so quit gloating!
Old 11-30-2011, 05:38 PM   #14
Aww, gee Dex, didnt mean to rub it in, you know.......Tonight its gonna dip down to maybe 55............brrrrrrrrr...........LOL!!
Old 11-30-2011, 05:49 PM   #15
Rewards Points: 120
Supposed to be something like 24 here, I think. Oh well, I've been all over the country, and always come back home, so it must not be that bad. Actually don't mind it at all, except for the fact that it does make it hard to work on things like you're doing with that motor, but I have a shop within my shop that I can throw some heat in at a reasonable enough cost, and at least avoid frostbite.
Cost-Benefit for electric vs heat pump, do my calculations look sound? chazman113 HVAC 13 08-13-2010 03:37 PM
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 09:25 AM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
