Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-12-2011, 04:15 PM   #1
Electric Furnace
Are Electric Furnace a good option for a 3400 sq ft home?
Alcarte is offline   Reply With Quote
Old 02-12-2011, 04:46 PM   #2
Master General ReEngineer
Bondo's Avatar
Electric Furnace
Ayuh,... It depends entirely on where ya are, 'n yer electrical Rates...
Old 02-13-2011, 07:30 AM   #3
Electric Furnace
Generally, in the US, electric heat is the most expensive option to operate. And there are areas where power supply is not all that reliable.
Old 02-13-2011, 11:12 AM   #4
Electric Furnace
i have a 2000sft home and ended up taking out my electric furnace and putting in gas. i think electric is one of the most expensive ways to heat.
comanche is offline   Reply With Quote
Old 02-14-2011, 07:17 AM   #5
Electric Furnace
Have you looked into the option of a heat pump system as well? It will heat and cool your house during the seasons. It would help to know your location.
MBatson is offline   Reply With Quote
Old 02-17-2011, 06:16 AM   #6
Electric Furnace
Proper maintenance will help you avoid many common furnace problems. Before you start your furnace troubleshooting, make sure that you have performed the suggested maintenance. Ensure that the thermostat is on heat and the setpoint is above room temperature.Nice information.
Blue Heron is offline   Reply With Quote
Old 02-23-2011, 08:13 AM   #7
Electric Furnace
How does this answer the posters question?
Ron
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
heat pump / ac unit vs electric furnace ellebt HVAC 4 01-12-2011 10:22 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
electric furnace need help Unregistered HVAC 3 10-16-2007 03:41 AM
