Electric Dryer No Heat At Times - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joed
Old 01-04-2017, 09:56 PM   #1
Rewards Points: 4
electric dryer no heat at times
Hi
At times I have an electric dryer that will heat up and work just fine. Then at other times it will stop heating up but still be spinning. It randomly heats up and then doesn't. I checked all thermal fuses, cycling fuse, etc and everything checks out ok. I checked for continuity on heating element and it was good. I inspected the heating element for cracks or a broken element and found it to be ok. There is not anything blocking the exhaust duct. And I cleaned all the lint from the back of dryer. Any ideas of what the problem is? Thanks for your help. Dave
Its a Kenmore dryer
Model # 100.60022010
kylo67 is offline   Reply With Quote
Old 01-04-2017, 10:35 PM   #2
joed's Avatar
Rewards Points: 12,000
Re: electric dryer no heat at times
Check the receptacle for a loose connection. Turn off the breaker first.
Mrbuilder likes this.
Old 01-04-2017, 11:14 PM   #3
Rewards Points: 4
checked receptacle and its fine. Actually, I checked all connections and they are fine.
Old 01-04-2017, 11:23 PM   #4
" I Can Fix It "
Mrbuilder's Avatar
Rewards Points: 114
Post
did you check the limit switches ? sometimes they'll be intermittent until they go. "they are fine" means no evidence of heat like blue or black terminals ?
" It's ok if you're not sure, find someone who is"
Mrbuilder is offline   Reply With Quote
Which wires do I unplug on thermostat to disable electric heat strips? mordak HVAC 5 11-03-2012 11:21 AM
Gas Dryer - Install Flex Line and Also No Heat mark2741 Appliances 8 07-05-2011 01:10 AM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 09:21 PM
Gas Dryer - Electric Dryer gannys General DIY Discussions 8 10-13-2008 05:50 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 11:45 PM
