Electric Cooktop Vs. Gas Cooktop - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-23-2006, 10:46 PM   #1
Electric cooktop vs. Gas cooktop
It's obvious which one heats up faster but which one hits you more in the wallet at the end of the month? I assume it's the electric one but I'm not sure.
Krichton is offline   Reply With Quote
Old 06-24-2006, 05:31 AM   #2
i had the same question and we went with gas. mainly cause my wife says gas cooks more evenly?!
THEBIGPUNN is offline   Reply With Quote
Old 06-24-2006, 06:59 AM   #3
jeff1's Avatar
Hi,
Might be interesting reading....
http://www.consumersearch.com/www/ki...fullstory.html
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 06-25-2006, 01:45 PM   #4
Lonicera's Avatar
Send a message via Yahoo to Lonicera
Another consideration
I like gas best, but next to gas I prefer an induction cooktop. Expensive to buy, but not as expensive to operate as regular electric. Wonderful temperature control, too.
Technical Details POWER FACTS
Stated Power vs. Delivered Power
Type Power Efficiency Delivered Power
Induction 2.8kW 90% 2.52kW
Gas 3.5kW 50% 1.75kW
Halogen 2.2kW 60% 1.32kW
Electric Coil or Cast Iron 2.0kW 55% 1.1kW
Time Required to Boil 2qts. of Water
Type Time Required Temperature of Cook Top
Induction 4 min. 46 sec. 230°F
Gas 8 min. 18 sec. 518°F
Halogen 9 min. 00 sec. 734°F
Electric Coil or Cast Iron 9 min. 50 sec. 644°F
Energy Consumption Used to Boil 2qts. of Water
Type Energy Used
Induction 225 W / h
Gas 390 W / h
Halogen 270 W / h
Electric Coil or Cast Iron 320 W / h
Lonicera is offline   Reply With Quote
Old 06-28-2006, 10:41 PM   #5
Property Manager
Gas would typically be less expensive to operate over electric. This is also why there are many more homes that heat with natural gas instead of electric. In fact electric heating can lower the resale price and marketability of you home --- at least in more northern climates. With a gas stove, there is also the faster response time when heating up and cooling down (off a boil).
MrNoMaintenance is offline   Reply With Quote
Old 06-16-2008, 07:26 AM   #6
Induction vs gas
Hi
induction cooktoips are supposed to give the same degree of control as gas and are a very efficient means of transferring heat to the contents of the pan. They are energy efficient in that less heat (energy) is lost to surrounding areas. This does not necessarily mean that they are cheaper to run in the long term. Two sites give more info that I found - the first I forget the link has detailed notes on energy usage including quotes from US government sponsored studies. The second site gives a general introduction and has a link to the first...http://www.induction-cooktop.com
Hope this helps
macic is offline   Reply With Quote
electric furnace need help Unregistered HVAC 3 10-16-2007 02:41 AM
Convert from electric heat to oil/propane? Badfish740 HVAC 7 05-15-2007 11:17 AM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 03:45 PM
