Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-27-2011, 10:36 AM   #1
El dorado wall caps arent sticking
Im building a stacked cinderblock retaining wall with cultured stone and eldorado wall caps. The cultured stone has stuck on the face of the wall with no problem but the wall caps down want to stay down. With little to no effort they pop up, basically the only thing holding them on is gravity. The mason supply that sold them to me said us the s type mortar and make sure you have a level mortar bed. I did with no luck. Im wondering if I can use some cement construction glue? I read somewhere that it doesnt hold up outdoors because of the moisture. what do you guys suggest?
the caps hang about 2 inches over the cultured stone and about 3 inches over the back. Im really worried about the firepit as the 9 inch caps i got for the fire pit. People will rest there feet on the fire and it will get more use and obviously be subjected to more wear and tear because of the heat from the fire.
scotzilla is offline   Reply With Quote
Old 07-27-2011, 10:40 AM   #2
There are adhesives specifically designed for stone. They typically come in tubes like caulk. Any big box store should have them.
self sticking tiles - wall application peter_d_holmes Tiling, ceramics, marble 12 03-13-2011 06:18 PM
Cutting retainer wall caps to fit a curve georgeandkristy Landscaping & Lawn Care 1 10-10-2010 09:45 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
