-   -   effloresence (http://www.diychatroom.com/f2/effloresence-18420/)
joshm 03-12-2008 07:32 PM
effloresence
I know that it means there is some amount of water seeping through the wall, but the wall is never actually wet. My question is, is the fact that there is effloresence on a block wall in my basement a sign that something is structually wrong or will it lead to structual damage?
Tscarborough 03-12-2008 07:46 PM
Efflorescence is generally only an appearance issue, but it DOES indicate a problem with water infiltration on older construction. That is, it is common and not an issue on something newly built, but if it appears on something built long ago, there is an issue.
joshm 03-12-2008 07:59 PM
Would bring in dirt to add a better slope away from the house help to fix this problem. It is fairly flat now or slopes even slightly toward the wall. I planned to bring in dirt to go from about 12 inches over 10 feet or so. If not, On older homes where this is happening, is putting weep holes to drain the block cores enough to prevent any structural damage?
Tscarborough 03-12-2008 08:09 PM
You won't live long enough for it to structurally damage the wall (the efflorescence), but grading the dirt away from the wall should help the water infiltration (which could destroy the wall).
joshm 03-12-2008 08:52 PM
So the water infiltration would eventually cause probems but would take forever? Or the water infiltration could damage it soon but the effloresence itself wont damage it?
Tscarborough 03-12-2008 08:56 PM
Efflorescence is a symptom of water infiltration. Efflorescence does not generally damage the wall, but the water infiltration does.
joshm 03-12-2008 09:00 PM
so I guess my question is, is this something I need to be corned about? Thanks again.
Tscarborough 03-12-2008 09:30 PM
You need to be concerned about the water infiltration.
