Efflorescence? Or Mold? Pictures Inside! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 08:17 PM   #1
Rewards Points: 115
Efflorescence? Or mold? Pictures inside!
Recently bought a house and finished renovating. I am now cleaning out the garage to turn it into a workshop/gym.
There is what seems to me to be either efflorescence or mold around several spots on the concrete floor, and also on one of the concrete walls that has dirt all the way up that side on the outside.
I used a mop and bleach/water mixture and cleaned out the whole garage including the walls. Problem now, there are a few spots that the white substance keeps re-appearing. I cleaned these spots AGAIN with a stronger bleach/water mixture, and it was back the next day.
Do you think it is efflorescence or mold? Is there a clear answer or way to find out besides hiring a company to test it?
6fthook is offline   Reply With Quote
Old 01-05-2012, 08:20 PM   #2
joed's Avatar
Rewards Points: 13,354
Effervescence from water under the slab apparently coming up the cracks.
Old 01-05-2012, 08:26 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That's not mold. If anything it is efflorescence but more than likely a mineral deposit from bleach water.
Tell you what. Keep the bleach on the shelf and clean it again this time using white vinegar. If it blooms again it is efflorescence. Harmless efflorescence.
By-the-way...
Effervescence is what you get when you pour a glass of Pepsi Cola or throw some Alka-Seltzers in a glass of water.
Efflorescence is the result of natural salts in concrete mixed with moisture and rising/migrating to the surface/warmer air in an attempt to evaporate. Basically a mineral deposit-like flowering.
XXX
Old 01-05-2012, 08:34 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
It is effloresance. They sell cleaners that will help your problem. I would stop using bleach.do a quick google search and you will quickly find all your answers.
Millertyme is offline   Reply With Quote
Old 01-05-2012, 09:29 PM   #5
Rewards Points: 115
Thanks for the quick replies!
I will try white vinegar to clean it out and see what happens. 50/50 water/vinegar ok?
I will search for the cleaners you speak of.
Thanks again guys!
Old 01-05-2012, 10:12 PM   #6
joed's Avatar
Stop the water penetration and the problem will be solved. No amount of any cleaner will help if the water is still entering. It is the water entering that is bringing in the minerals.
Old 01-05-2012, 10:32 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...and how would you suppose he could do that?
XXX
Old 01-05-2012, 10:53 PM   #8
Rewards Points: 14,026
It was a poorly pored floor, improperly back filled and compacted with no vaper barrier under it so there's not much you can do about the moisture that's causing this from coming in.
You can clean it all you want to but it will come back.
It may help to add some gutters add a french drain or regrade around the building.
Old 01-06-2012, 07:45 AM   #9
joed's Avatar
That would require much investigation. It could be that the entire foundation needs to be dug out and proper drainage installed. Maybe the floor needs to be broken up and fill and drainage installed from the inside. Maybe he just needs a new sump pump to keep up with the water level. Maybe the sewer line is broken and leaking under the slab.
Old 01-06-2012, 07:56 AM   #10
Civil Engineer
Rewards Points: 4,860
Efflorescence is harmless to humans, as the salts are carbonates and occasionally sulfates. The material is similar to the mineral deposits you get in caves from water percolating through limestone. Relax, it isn't going to hurt you, and the cost to "cure" the "problem" will definitely put a big dent in your pocketbook. You can sweep it up every so often if you don't care for the appearance.
Old 01-06-2012, 08:22 AM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
In time it will cure itself, until then it should be a non-issue.
XXX
Old 01-06-2012, 02:26 PM   #12
Concrete & Masonry
Rewards Points: 620
Efflorescence. Short of tearing out the floor, placing a vapor barrier under it, and re-pouring a new floor, there's not much to fix it long term. There are sealers that claim they'll create a vapor barrier on the surface, but I'm aprehensive to believe it would last very long.
jomama45 is offline   Reply With Quote
Old 01-06-2012, 02:54 PM   #13
joed's Avatar
It will only cure itself if the water goes away. As long as there is water there will be effervescence.
Old 01-06-2012, 03:15 PM   #14
the Musigician
DangerMouse's Avatar
I wonder if it'd stop if you cleaned it and then did an epoxy floor?
DM
Old 01-06-2012, 03:54 PM   #15
EIT/DIY'er
I work in the efflorescence capital of the world (hydroelectric dam). There is no economically feasible way (at least for my wallet) to cure your symptoms, however it is structurally a non-issue and can be removed as often as you feel like taking a wire brush to it. It can be cleaned by a mild muriatic acid solution (be careful, it is nothing to mess with!), but adding more water can further compound the problem.
Lattimer is offline   Reply With Quote
Efflorescence do builders care Ianski General DIY Discussions 0 08-25-2011 09:33 AM
Mold on framing of bathroom wall CowboyAndy Remodeling 34 10-22-2010 06:53 AM
Mold inside exterior wall Chemist1961 Building & Construction 0 04-21-2010 07:55 AM
Posting Pictures rjordan392 Site Help and Suggestions 13 08-18-2008 08:25 PM
Is this Asbestos Siding or Cement Siding? Pictures inside!!!! twilightcall Remodeling 12 02-01-2008 07:27 PM
