Easy Way Of Removing Staples? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-23-2008, 02:04 PM   #1
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Easy way of removing staples?
I'm in the middle of re-felting my pool table and I've already removed close to a million staples! All I have left are the 2 side rail bumpers - the long ones. After the table top and 2 short rails, my fingers are killing me. I've been using the stab-and-lift method with a sharpened flathead screwdriver. I've been thinking that some hogring pliers or something similar might work, but maybe not with the deep staples and fabric.
Any ideas? I have to re finish the tops of the rails too, so I still have a bit of work to do and I need to get this done soon.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 05-23-2008, 11:31 PM   #2
(the original)
Rewards Points: 756
Yup, it's called an upholstery staple and tack remover. You should be able to find one anyplace that sells upholstery supplies.
You hook the fork on the tip under the staple and push down to lever it out, lots easier than pulling up with your screwdriver.
ratherbefishin' is offline   Reply With Quote
Old 05-24-2008, 01:24 AM   #3
Perhaps a very sharp hand held scraper and just lope them off.
raam is offline   Reply With Quote
Old 05-24-2008, 06:30 AM   #4
Tired, Cold, and Damp
slickshift's Avatar
Flat screwdriver, needle nose pliers
slickshift is offline   Reply With Quote
Old 05-24-2008, 10:32 AM   #5
31b
sparky
side cutters (dykes) work pretty well
31b is offline   Reply With Quote
Old 05-24-2008, 10:51 AM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
how about this guy:
If you Google staple removers and browse through the images, you will see many different types of staple removers.
Old 05-26-2008, 05:09 PM   #7
Advice worth 2 cents!
Rewards Points: 150
Originally Posted by nap View Post
how about this guy:
That, is one pretty tool!
- pete
---pete
HandyPete is offline   Reply With Quote
Old 05-27-2008, 05:19 PM   #8
Fixer-'til-broker
Rewards Points: 262
Thanks! It didn't even occur to me until now to use the staple remover right in front of me! I finaly finished and made my first break at around midnight this morning. If there is a next time I will just build the whole thing from scratch! There's that saying about polishing a turd...
I keep saying this, but I will post pictures soon. I promise.
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
staples vs nails shotdown Flooring 3 04-26-2007 06:55 PM
Laminate Flooring and Staples superfeely Flooring 2 03-22-2007 12:33 PM
removing knockdown texture K_I37 Painting 7 05-07-2006 02:23 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
