Easy Kitchen Faucet Install Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-04-2011, 04:00 PM   #1
easy kitchen faucet install question
I installed a new faucet and everything is great except the actual faucet is loose. Iíve circled the problem in the attached photo. The nut holding whatever the rubber part is to the sink will tighten to a point and then let go. It never gets tight enough to give the faucet a tight feel when handling it. How do I rectify this?
adamhodge is offline   Reply With Quote
Old 07-04-2011, 05:03 PM   #2
DIY staff
Rewards Points: 7,174
If the nut is popping loose then you either stripped the nut or the threaded shaft---
Either replace the nut or the faucet---not good--sorry.--Mike---
If it's the shaft you might be able to add washers or a spacer to avoid the damaged area.
Old 07-04-2011, 07:57 PM   #3
Rewards Points: 5,336
Are you sure you used all the parts in the correct order? It's hard to over tighten those nuts so close to the hose.
Ron
B. Franklin 1759
Old 07-04-2011, 08:08 PM   #4
Old School
Willie T's Avatar
Can you try removing the shaft, and reversing it?
FranÁois Duc de La Rochefoucauld
Willie T
Old 07-04-2011, 09:45 PM   #5
DIY staff
As I recall that faucet comes with a plastic wrench to tighten that nut----I wonder if the wrench split and pops open --failing to actually turn the nut.
Repair Instructions for Delta Kitchen Faucet BigJim Plumbing 2 04-07-2011 10:36 AM
kitchen faucet with spray nozzle, dishwasher and garbage disposal iklektic Plumbing 2 03-24-2011 10:53 PM
Replacing a kitchen faucet Anna123 Plumbing 3 06-09-2010 05:48 PM
Receptacles Behind Gas Range Install - Question IIchrisII Electrical 4 07-27-2009 08:37 PM
tub faucet install question amakarevic Plumbing 5 06-25-2008 07:34 AM
