(Easy) Finding The Correct Angle ...? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-27-2015, 07:34 PM   #1
Rewards Points: 6
Question
(Easy) Finding the correct angle ...?
So ... I'm making a huge chair for my parents pool room and I want to make the front of the chair wider than the back (by a little bit). I just forgot hot to find the angle that I need to cut all diagonal pieces at so they would be flat on the back/front legs. (I am making it out of 4 by 4s ... its going to be beefy.)
Measurements:
(Excluding the legs)
Back=18"
Front=21"
The other measurements don't have to due with the angle.
I know this is simple but i seemed to have forgot how to figure out the angle I need. Thanks!
Alder Evergreen is offline   Reply With Quote
Old 11-28-2015, 04:11 AM   #2
GrayHair's Avatar
Rewards Points: 1,002
There is another measurement that affects the angle: the depth. Drawing is exaggerated to illustrate the point.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
The Following User Says Thank You to GrayHair For This Useful Post:
Colbyt (11-28-2015)
Old 11-28-2015, 07:57 AM   #3
Rewards Points: 3,865
And the really old way is to lay it out on a the floor or a table and scribe the lines, cut a piece of scrap and see if it fits.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 11-28-2015, 10:01 AM   #4
GrayHair's Avatar
No reply yet, so I'll just post a formula.
Old 11-28-2015, 11:38 AM   #5
Rewards Points: 6
Thanks Mithrandir !
Sorry for leaving out the other measurement, so with
Back=18"
Front=21"
Depth=18"
Following your formula this is what I get.
4.76= tan^(-1) (1.5/18)
So basically its 4.8 degrees ?
So I line that up in an angle square and I should be good to go right ?
Thanks again!
Old 11-28-2015, 12:15 PM   #6
GrayHair's Avatar
I also get 4.76.
OBTW: That 18 between the front and back should be the inside-to-inside measurement as shown by X below. If you don't add some length to the front, you'll loose it off the back (see blue line).
Alder Evergreen (11-28-2015)
Old 11-28-2015, 11:10 PM   #7
Rewards Points: 6
That's a good point I never thought of that. Thanks again for everything !!!
Old 11-29-2015, 09:01 AM   #8
GrayHair's Avatar
I didn't think of it either, until after I had posted. The Oh By The Way and graphic was an Edit. I saw no way to add the graphic in the basic Edit screen and had to Go Advanced; where there was no Reason for Edit box. Anyway, you saw it and that's what counts.
Don't forget pictures of, at least, your completed project.
Tags
angle
Crown angle for slanted wall emaxxman Carpentry 9 01-15-2012 12:29 PM
Hard time finding angle valve for toilet Repairtag General DIY Discussions 14 01-02-2012 09:16 AM
What correct mix for building a stone foundation wall? & correct mix for stone fireplace. world travler Building & Construction 0 08-04-2011 06:39 PM
finding an unknown angle with trim stud Carpentry 4 06-22-2011 06:16 PM
angle grinder question itin1200 Tools 8 07-13-2010 07:07 PM
