Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-10-2012, 09:54 PM   #16
Easily undone knot for lifting?
Originally Posted by mae-ling View Post
I had said I remember pulling a tail for it to come undone.
With a standard clove hitch you can not pull the tail to untie.
But the old Hydro man you knew probably knew how to tie the modified clove hitch that I tie and it can be untied by pulling the tail. The modified clove hitch is just something old men learn over the years and those things never make the books so therefore never getting passed on.
Fairview is offline   Reply With Quote
Old 09-10-2012, 11:11 PM   #17
Metal Roofing
The one we used to secure items to a rail was this. This would not be adequate for truss lifting without a couple of additional half hitches. Adding the half hitches would prevent pulling on the bitter end to release the modified clove hitch...you would first have to release the half hitches before pulling the bitter end to release the clove hitch.
AndyWRS is offline   Reply With Quote
The Following User Says Thank You to AndyWRS For This Useful Post:
mae-ling (09-11-2012)
Old 09-11-2012, 12:01 AM   #18
I use that knot in a chain to pull 6" walnut tree stumps with a 6 ft. tap root using a 75 HP tractor and it took all 75 horses so I see no reason it wouldn't lift a truss.
Old 09-11-2012, 01:53 AM   #19
Andy that looks like it might be it
mae-ling is offline   Reply With Quote
Old 09-11-2012, 07:08 AM   #20
Haverhill Trade 1965
I would bet a version of a half hitch. Instead of putting the tag end through make a loop and put it through. then just pull the tag end, the loop comes out and the knot drops off.
Duckweather is offline   Reply With Quote
New garage floor is chipping and dissolves easily. AAL Concrete, Stone & Masonry 1 06-04-2012 06:47 PM
LM IPE Floors scratching too easily? coachgns Flooring 7 02-10-2011 09:35 PM
Is there a way to prevent a Marcraft vanity top from scratching so easily? Swazzle Remodeling 2 07-22-2010 04:24 PM
Veranda composite post sleeves fit easily stansongman Carpentry 10 09-26-2009 02:31 PM
Spray primer Kilz latex now all finish paint is soft and easily peelable dorothyolive Painting 29 11-02-2008 06:14 PM
